tykoehn1
Good day to rest! How do you like the belt drive? Did you check the tension? Also have you played around with the front shock air pressure?Brutal wet and windy day! No bike adventures today![]()
I hate covid. They are basically saying that your bike wont be done until the end of January. After my bike was finished, it still wasnt shipped until a month later even though i was told it was "shipped" at the middle/end of OctoberThis is starting to get really f-ing annoying...View attachment 73396
The belt drive seems fine so far, nothing to be concerned about certainly. It seemed super tight when i first built it up out the box, but has loosened off a little now i've put a few miles on it, i think it's more the belt has softened up a tiny bit. It has a little play in it now but still very taught. All normal i think You get an app from "Gates" but to be honest i think so long as it's tight your good. I've played with the lockout a bit but not the air pressure yet. I carry a small rechargeable pump in my back pack so may get round to it. The tyres take a bit of pumping from flat.Good day to rest! How do you like the belt drive? Did you check the tension? Also have you played around with the front shock air pressure?
I was thinking about getting an actual tension measuring tool from amazon. it seems tension is important to prevent skipping. Im not sure how accurate the phone app will be but its better than nothingThe belt drive seems fine so far, nothing to be concerned about certainly. It seemed super tight when i first built it up out the box, but has loosened off a little now i've put a few miles on it, i think it's more the belt has softened up a tiny bit. It has a little play in it now but still very taught. All normal i think You get an app from "Gates" but to be honest i think so long as it's tight your good. I've played with the lockout a bit but not the air pressure yet. I carry a small rechargeable pump in my back pack so may get round to it. The tyres take a bit of pumping from flat.
++++The tyres also come flat in the box, mine were anyway.++++
++++I used a foot pump to pump mine up so would be wise for any of you guys waiting on delivery to have a pump @ hand also.++++
You'll pay just before it gets shipped and alibaba holds it till you confirm delivery. Make sure everything is 1000% with your bike before you confirm delivery!This is starting to get really f-ing annoying...View attachment 73396
Good stuff.... watch this also.I was thinking about getting an actual tension measuring tool from amazon. it seems tension is important to prevent skipping. Im not sure how accurate the phone app will be but its better than nothing
Check out this link to the luna fat babe. It talks about drivetrain tuning/adjustments/troubleshooting
Luna BABE bike - Electricbike.com Ebike Forum
babe.jpg Warning, would should never shift under load (that includes throttle and pedal), you can pedal while shifting but you need to avoid putting any pressure on the pedals! It's the same for all IGH hubs (ebikes or non-ebikes). Shifting under load will likely result in a misshift, permanent...electricbike.com
I'm sure if it's the proper Gates app and not a 3rd party thing it must be cool to use. I doubt gates would put their name to it if it wasn't going to work with their belt? Also if you were going with the luna one you'd find yourself in trouble off rip as the yellow lines on mine didn't line up. There is one yellow and a scratch mark so i take it they did it that way at the factory. Loads of great info though. That's what's good about this site, it seems a bit of all the info is correct and following just one will get you in trouble. Having a few to bounce ideas and tips about is a good thing. Will keep us all right.I was thinking about getting an actual tension measuring tool from amazon. it seems tension is important to prevent skipping. Im not sure how accurate the phone app will be but its better than nothing
It says they are, i'd re-tape the holes on the rims just to be safe though. The tape already on is fine for tubes but i'd re-do with better quality tape if i was going tubeless.Are the wheels tubeless ready?
No problem.Thanks Terry!
When the speedo is correct at 20 m ph than the rest should be accurate too.
I was curious with pedaling cuz only 5 gears with belt.
Never drove those.
I will choose the 750 hub, cuz I dont drive that much
on my current e bike I had to change front blade, bigger, otherwise K could not keep up
I used the same app to track the container ship that carried my MD1000. Its good that they use an East coast location for you guys. Ground shipping is where damage is most likely to occur. I hope you don't have the delay with Customs I had. Added 2 weeks and counting to the time.According to my bill of lading, my bikes are being delivered in Charleston. I tracked the ocean vessel name on vesseltracking.com and the vessel is going to be in Panama on december 7th. Last time it was spotted it was going 21 knots around the baja peninsula. Looks like a Christmas deliver will be cutting it close.
Nice one buddy! I hope it arrives sooner rather than later for you.According to my bill of lading, my bikes are being delivered in Charleston. I tracked the ocean vessel name on vesseltracking.com and the vessel is going to be in Panama on december 7th. Last time it was spotted it was going 21 knots around the baja peninsula. Looks like a Christmas deliver will be cutting it close.
Totally agree with the horses for courses comment.Re Hub vs Mid, it's horses for courses:
I have a Specialized Turbo Creo road/gravel bike mid drive. It's only 250W with Pedal Assist (torque sensor, no throttle). Riding the Creo is like riding a acoustic bike and the power applied is almost unnoticeable unless I change power modes e.g. Eco to Sport mode. It is very stealth looking and most people don't notice that it is an ebike. The power application is very smooth and it's like having bionic legs with the only giveaway being the faint whirring of the Brose motor. I can comfortably ride the Creo on flat ground at 25 mph in Sport mode. It has a Turbo mode which ups the speed to about 28 with the same effort but at a significant power consumption penalty. This is my clipped in workout machine and so it pretty much balls to the wall when riding the 32 mile bike trail that is near my home.
I also have a fat tire folder with 500W hub motor that has both PAS and throttle. It was my first ebike and I have put >2400 miles on it since last March. The PAS and throttle on this bike are more powerful and crude in their implementation. I expect the MD 1000 to be that on steroids but look forward to having the extra power and speed at my disposal.
The MD 1000 replaces the Fat Tire folder and will be the ebike I take on road trips (vacation riding exploring) and casual riding with friends and my wife (she has a Blix Aveny). Also the MD 1000 will be used any time I want to not gear up (clipless shoes and cycling garb) and get somewhere fast carrying cargo. My guess is I will be fine with the power application as stock, but it's nice to know that the controller can be tweaked should I feel the need.
As to the size of the MD1000, my Creo is a XXL model (riders 6'4" - 6'9") so big is relative. Also, I was able to test ride prototype HD 750 (SRAM 9 speed) and the MD 1000 (SA IGH) at a dealers shop in my area. That's what hooked me on this bike and has me anxious like a kid waiting for for Christmas. At the current rate, it may be Xmas before I actually get it ...![]()
Yeah, riding the Fat Tire folder I felt like the circus bear riding the bike. When I first saw the MD 1000 is was cool, size appropriate! I'm used to things not fitting me and of course you are right about it being a large bike. I recall the Bolton video introducing the MD 1000 and the HD 750 and he specifically mentioned that they are big and not really suitable for shorter folks. I'm glad it has worked out well for you and thanks again for all your contributions here ...Totally agree with the horses for courses comment.
I haven't been on anything else to compare it to but the MD1000 is for sure "somedamnthing" on steroids! It feels like I am on steroids when i pedal it! The PAS has to be felt to be believed!
Because it's so damn big, and i am just a normal sized guy i bet there have been people who can't believe it's only me making this monster move by just peddling it.
It must be the same kinda reaction you'd get i ran past you with a racehorse on my back or something daft like that! LOL
