Hi guys, Brent shot this little video about belt drives vs. chain drives when he was reviewing the Pure Cycles Volta Single Speed and Volta 8-Speed and I thought it deserved a little guide to go along. I ended up adding a few points to his original video because I've tested the Gates CDX belt drive and some others on many more bikes which utilized the NuVinci continuously variable transmission (CVT), Shimano Nexus internally geared hubs, and Rohloff Speed Hub system. You can definitely use gears with belt drives... but they have to be internal vs. a traditional cassette+derailleur setup. Here's the video we created and I've listed some pros and cons below that. Feel free to chime in with your own thoughts on benefits and trade-offs.
Pros of belt drives for electric bicycles:
- Clean and quiet, they won't rust like chains sometimes do and they don't require lubricant that makes a mess when touched
- Extremely durable, a high-quality belt drive from a company like Gates won't wear out as quickly as most chains
- They don't fall off as easily, since belt-drive systems don't use a cassette and derailleur, there isn't any extra slack for changing gears so they won't bounce around and fall off as easily
- They almost always cost more because the bike frame has to be design so that the belt can pass through the rear triangle of the frame. Some frames have been designed to work around this design challenge by passing both portions of the belt below the chain stay vs. around it (both above and below)
- Without a derailleur and cassette, you are left with a single speed or internally geared hub or continuously variable transmission... and these two later options tend to weigh more and cost more
- Trail maintenance isn't as easy because you cannot simply replace a link or rely on a tensioner to keep the belt taught, you actually have to adjust the horizontal tension... and this can limit how much power the drivetrain can handle from a mid-motor
