Blakeman62
- USA
Can this be done on both drive system? Is one going to be harder to pedal than the other? Will it damage anything on the bike to do this?
Can definitely be done on my hub-drive — just did it today for some quickie laps around my flattish neighborhood. Hard for me to imagine what damage it could do.Can this be done on both drive system? Is one going to be harder to pedal than the other? Will it damage anything on the bike to do this?
Absolutely! Test results for rolling resistance of fat tires show that a single fat tire may require even from 30 to 50 W of power (60-100 W per bike) to overcome the rolling resistance, which means the motor support is necessary to ride a fat e-bike, and the throttle is required to move the e-bike from a dead stop.But many bikes equipped with fat tires are not very suitable because they are too heavy. The thicker the tire, the greater the rolling resistance.
Some mid-drive riders report that their motors are significant drags on their drivetrains when the power's off, but other riders of the same bikes dispute this. And many others say not on their makes or models. So no idea where the truth lies here.
I didn't think about it. Isn't the phenomenon caused by generating the counter electromotive force when unpowered? And... DD motors are very heavy.A direct-drive hub motor has cogging resistance. All other ebikes should pedal with minimal resistance.
That's true (it is 25 km/h in the EU) but unless you are assisted by tailwind or a road decline or your legs are really strong, it is hard to pedal a heavy e-bike above the speed restrictor. It is certainly easier on an aero and lightweight road e-bike with skinny tyres.Don’t forget that in the UK, if going of 15.5 mph, then the motor is not working anyhow.
The more rotational inertia (RI, aka moment of inertia) in the wheels, the more total torque (rider+motor) it takes to accelerate a bike from Speed A to faster Speed B in a fixed amount of time. And the more braking torque it takes to slow from B to A in that time.With the hub drives it is just a matter or rotational weight. It takes a bit more to get it spinning from a stop. Then the inertia makes it stable and stopping takes more force to bleed off the momentum.
