indianajo
Direct drive hub motors feel with power off as if you are in 2 sprockets higher than you really are. These can be 10-15 lb with battery. Geared hub motors with power off have an overrun clutch (except gmac) so they feel as if you are carrying same weight (8-15 lb) of supplies or accessories uphill. On the flat, no penalty. Drag of tires depends on the model of tire and fat ones are both unpowered pigs and energy (watthours) hogs when running with the motor.
Mid-drives from bafang, shimano steps. brose, yamaha ehave an overrun clutch so power off they feel the same as the additional weight uphill. Middrives from bosch, except the most expensive, you drag the motor with your feet power off.
