AntonioAlfaro
- Other
Grinding Noise
What seemed perfect ceased to be so. My odometer has crossed the 1000 km mark, and in the last three rides, a terrifying noise started coming from the TQ50 motor of my 2023 Domane+ SLR. For a moment, I thought some mechanism inside the engine was being ground because it was an abnormal noise I had never heard before. After my initial terror subsided a bit and and thinking about my return home, I began to notice that this deafening noise occurred under certain circumstances, but most of the time or when the motor was in OFF mode, it did not happen. I found that the grinding noise was correlated with my cadence, the power from both me and the motor, and the rear gear ratio. The noise didn't occur when I was climbing a hill, applying power to the pedals. It happens when you're on a flat slope, stop pedaling for a moment, and then start rolling again. When you begin pedaling again, there seems to be a kind of desynchronization between the motor and the pedal axle, and the grinding noise appears. It's as if there are unsuccessful attempts to engage the motor with the transmission axle. During these moments, I observe that I'm delivering some power, I'm over-rotating, and the motor is delivering very little power (no more than about 10W). However, if I shift to a higher gear, reducing rotation and increasing the power delivered by the motor, the noise disappears completely. As long as the motor is delivering enough power (more than 30W, I'd say), the dreadful grinding noise doesn't occur.
Is this an intrinsic characteristic of the TQ50 motor? Is it a design flaw? Is it a software issue with motor control? Is it normal and should one simply avoid the conditions in which it occurs?
I'd like to know if anyone in this forum is experiencing the same noise.
