AntonioAlfaro
- Other
Searching a bit in various forums, especially in MTB forums that use the TQ50 motor, I come across the fact that this same issue is well-known to them, and they have even received a response from the manufacturer clarifying their stance. I am attaching a YouTube link where I found the following response from TQ:
"@RobRidesEMTB
To add - the motors are near silent on descents - barely any noticeable rattles (especially compared with Shimano / Bosch)Also, TQ responded to a small number users experiencing noises. Here’s what they said:
Hey Rob! Just wanted to give you a quick heads up regarding the noise discussionsWe are currently working on this topic. It has no influence on the motor’s performance or durability and seams to be no more than a peculiarity of one of the sprag clutches of our motor. If the motor’s assist is very low (less than ~ 10W) it seams that the electric motors torque is not enough to rotate the clutch, but not fully engage it. This can lead to the weird rattling/grinding noise. The forces in such a scenario are however extremely low and do not put any mentionable wear on the internals of the motor. From everything we know and all the 1000s of field testing kilometers we have already done this issue is nothing to worry about. Nevertheless the low noise is one of our strongest USPs and we are working on a solution. We believe that some tweaks in the motor controller algorithm could reduce or even completely remove this noise. Our goal is to roll out a software update before the end of this year.
"@RobRidesEMTB
