TAZMANIMAN
I'm going to throw in another perspective. I am handicapped with Muscular dystrophy and I can notice very minute differences in how much strength I need because I don't have much. We have a hill nearby that is quite steep. When I am in pas5 I can definitely pedal easier but when I get near the crest I still usually have to add the throttle and it makes up the difference. Maybe they set the throttle parameter higher. Also you can slowly roll on the throttle while using any Pas setting, we usually use Pas1 and if I get to a quick hill I only give enough throttle to take some of the effort away, I still maintain my pedaling because I do want the exercise. I like the variability that the throttle gives allowing you to challenge yourself on inclines but still maintain a pace. My thoughts are the pas settings are all designed to cut off at progressively higher speeds but the throttle can give a true maximum.
