ST7 setup, what to check?
MinnBobber
For a new in crate Plat Grey ST7, what things should the dealer give special attention?
….where some ST7s have had this issue….
1. Power cable to rear disk clearance. Make sure there is ample clearance.
2. Check that regen brake totally disengages when not braking.
3. Check brake lines for air bubbles, especially the front with tricky ABS line routing.
4. One person said their ST7 ABS was not working but kind of iffy…
What else should get special attention??
Thanks for any items that the dealer should check…..
Check all of the fastener torques, make sure the kick stand spring doesn't rub on the rear tyre when folded up. ABS works fine, unless a fault is signaled or there's air in the line.
