Nvreloader
- USA
I am attempting to add mph & cadence into my log book.
I am using this calculator = https://www.gear-calculator.com/,
I set all the info block to match my gearing and speed per OEM Display and my accurate Gramin GPS 60cxs, all the info blocks can be change via the gear/wheel display at the top right corner.
I then move the cadence block until the speed matches the display and GPS readings,
then get the cadence info. (Click on wheel center for minute changes)
I know the display is off, (can't change it, tire set for 26",) as compared to the GPS readings.
44T Ring and 34T back gear = 100# bike and 200#'s for me,
26.5" Fat Tire @ 15 psi F and 20 psi B = 2350mm tire circumference (measured) = 29.5" tire Dia,
No power, display is on to read the info only,
Speed = Display vs GPS - cadence readings for both/Manual Pedal only
Mph = 6.4 Display vs 7.0 GPS = 52 rpm -62 rpm cad
44T ring and 34T gear
Power on, Eco -1 step,
Speed = Display vs GPS - cadence readings for both/Pedal Only
Mph = 7.1 Display vs 7.4 GPS = 63 rpm -66 rpm cad
Speed = Display vs GPS - cadence readings for both/Throttle Only
Mph = 15.0 Display vs 15.5 GPS = 133 rpm -139 rpm cad
All the above reading were taken 2 times = up and back, for the same distance/wind factor.
Would these be accurate readings/SWAG?
Your thoughts and suggestions..........
Tia,
Tia,
