Specialized, Trek or Orbea, which one?
Glad to hear orbea included a 100 g one way clutch. That allows no drag pedaling when feet are faster than motor. I got my information from orbea website: www.orbea.com/us-en/ebikes/road/gain/cat/gain-m20i-20mph/
which says the motor is a Ebikemotion X35 Plus 20mph
I don't see any hub drives in the picture. Maybe firnatine has access to some old stock in a bike shop near him.
With the kind of support vehicles Firnatine is reporting, wearing out chains in his 8000 mile trip should not be a problem. In the group rides around here, I was sometimes the guy changing tubes for the road bikers, while the sag wagon was way to the rear helping the newbies on kiddy bikes that weren't prepared for any distance.
Supposed to be 65 Tuesday Wed, and more important 55 Tue night. Will ride out my first 30 miles of the year to see what was stolen or fell down this winter.
It is a rear hub motor. The hub is smaller then the cassette thats why you can't see it in the picture.
That didn't sound right, so I just checked and at least here in the US, all Specialized e-bikes are mid-drive and use a Brose motor.
You are right, Specialized does not use Mahle motors but at the same time you are wrong about them using a Brose. Specialized SL1.1 motor was designed
and made for all their turbo eBikes. No other eBike uses it since its proprietary for Specialized only. Thanks for all the comments everyone. I'm 95% sure I'll be going with the Specialized Turbo Creo Evo.
Must be a lot of misinformation on the web then. I found several articles stating that Specialized uses motors that are made by Brose.
All full power Specialized Turbo e-bikes (that is, Levo, Kenevo, Vado and Como) use Brose motors. All "superlightweight" Turbo e-bikes (Creo SL, Levo SL and Vado SL) use a Mahle motor.
Firnatine: You are right these motors are "Specialized" because Specialized took part in both customizing these motors as well as tuning them to specific purposes:
  • Specialized 1.1 is made by Mahle (all SL e-bikes). That motor is made per order of Specialized only and unavailable to any other brand.
  • Specialized 1.2e is Brose CB
  • Specialized 1.2 is Brose T
  • Specialized 1.2s is Brose TF
  • Specialized 1.3 is Brose S Alu
  • Specialized 2.1 is Brose S Mag
The brose motor developed a reputation as unreliable in the mountain bike world during 2019 , which is a shame because it's a lovely motor.
It's about the 2.1 motor. Specialized took care to greatly extend the warranty and fix the issues in new 2.1 motors.
Is the motor in the SL models a proprietary design that's made for Specialized by Mahle then? Just trying to understand and get educated.
Correct
Specialized worked with mahle to produce the motor used in their sl range. This is in the bike you are looking at.
Specialized also worked with brose to produce their full power motors, hence the confusion from the other people posting
The brose motor developed a reputation as unreliable in the mountain bike world during 2019 , which is a shame because it's a lovely motor. So far, the new SL / mahle motor seems to be very reliable - they put a lot of effort into waterproofing etc
Correct
Good review on youtube. At about 5:35 into the video they discuss the new motor.
You'll find a lot of good quality discussions about the motor if you research the levo sl . The ultralight motor has created a lot of interest in the mountain bike world.
I have a Gain and I have been test riding both the Domane + HP and the Creo. If you want longer range and a wide power band the Domane is best. When I was riding it I was pretty sure that I would always use power because of how much it weighs. Both the Orbea and Specialized both ride very well with the motor off. Orba uses the ebikemotion hub and Specialized the proprietary mid drive. Both motors are made by Mahle. The hub motor used by Orbea feels stronger and is spected at 40 nm. The mid drive on the Creo is rated at 35nm and is class 3. It has a larger primary battery. Both have the same battery capacity after adding extender batteries and most likely have similar range. Neither has the power of the Trek. The components on the base carbon Creo are not as good as on the Gain, in fact they seem pretty basic for a $7000 bike. The Gain has Ant+ and connects to Garmin and other computers, this doesn’t seem to be the case with the Creo. I decided to keep riding my Orbea.
At 70 now, I have been consistently putting around 7,000 mile per year on my bikes for the past 3 years since I resumed riding after three decades. I have been riding some heavy equipment but as the tech has improved and good light weight ebike have come to market, I have been moving that direction along with the industry trend.
I test rode the Turbo Creo in Carbon and found it gorgeous. I also have a close friend, a former bike racer who is in his fifties, who owns one and loves it. I ride with him frequently. It is an awesome bike but lacking oomph especially in the steep hilly place I live in. My conclusion is that performance compromises were made to avoid the "embarrassment of riding an ebike"
I also rode the new Domane+ HP in the middle version. I liked the look and feel of the bike and the power of the Bosch speed motor. It does have a considerably fatter downtube that gives away it "E" identity. Just because it has more power, you don't have to use it. It is nice to have it in reserve when wanted though, like dashing back for shelter if the weather turns. I was disappointed in the drive train Trek put on this bike as it lacks gear range at both the speedy end and for climbing. At that price point they should be putting their microspline 12 speed with the 10-51 tooth chainring. (which is the one I have on my Trek Allant 9.9+).
What I ended up buying was the Cannondale Topstone Neo Carbon 3, It has the Bosch Speed Motor with the 500 watt battery and weighs in at 39 lbs. They really leaned out the downtube as much as they could and still hold a full 500 watt battery. You have to slowly wiggle it out with the two sides wanting the hold the battery in place and carefully align it putting the battery back in. It also has a really innovative suspension both front and back and gets way better range than my Trek Allant due to its significantly lower weight (14lbs).
Cannondale makes the 2 version with a fixed fork, 2x11 drive train and weighs in at just 36 lbs.
They, like most high end ebikes, are hard to find right now, especially in certain sizes. I have been riding mine for two weeks now and just loving it. I have been doing exhaustive looking recently for my bike and would be glad to share what I found and where, if you decide you want to go that way.
I've ridden both the Orbea and the Creo. I bought the Creo because the Gain is so weak at hill climbing, as is typical of hub drives. The Creo is a mid drive, generally much stronger on hills. I own a hub drive ST2. Hub drives are strong on the flats, but flat on the hills.
The Creo connects to Garmin devices. No problem. The Garmin eBike screen displays all Creo data: cadence, power, batteries, etc.
Additionally the Gain has a cadence sensor that drives the motor. The Creo has a torque sensor. Give the Creo some pedal, and it smoothly delivers watts. The Gain drove me nuts. You have to find the right cadence to get it to deliver power. Starting from a standing stop going up a hill was no fun on the Gain. Cadence sensor + hub motor = meh.
I previously had an Orbea Gain and I agree with all your points. It was fantastic as a bike but it wasn’t a fantastic eBike.
Good to know about the connectivity, the Specialized dealer said it did not connect, but he was not very knowledgeable about the bike. I ride mostly with the bike off and only use it occasionally, might explain our different impressions.
I've read quite a few reviews on the Gain and other bikes that use the Ebikemotion X345 rear hub drive, and they are all very positive about the amount of assist in hilly terrain being quite adequate. So I suppose some people are just looking for way more assist than others are.
That is always the case around here. We are folks of various ages, various fitness levels and a wide range of cycling experience, some are capable bike mechanics while other have all work and adjustments done at an LBS.
That is why it is always good to begin an inquiring post with a brief statement as where where you fall in the continuum and also do so when you answer a question. That way each party can assess the relevance of the answer for their circumstances.
It’s good for what it is. The PAS is very good for a cadence sensor. The power is also decent for the wattage and battery size. Having said that, it’ll never match the predictability, responsiveness and natural feel of a torque sensor based PAS. And I do live and ride around the SF Bay Area. Launching from a standstill while going uphill is one of the many scenarios that a middrive, torque sensor based PAS can never be substituted. On a cadence sensor PAS, you always have that momentary delay where the motor needs to catch up and kick in. It’s not well suited for us hill riders.
Maybe. That and their ability levels and route choices were more suited to the hub based drive system.
Maybe. I liked my Gain while I had it. After trying a bike with a torque sensor, though…it was just too good to pass up. But everyone has a different riding style.
