'25 Orbea Wild M20 - display question
tgianco
Folsom, CA
My wife has a 2025 Orbea Wild with the Bosch Gen 5 motor. It doesn't have a display (Kiox), so her options are either using her phone via the Flow app or kind of guessing mode and battery level via the Purion (where you change assist levels, etc).
My question is:
1. How hard would it be to add the Kiox 500 (she likes the larger display of the 500 versus the 300)?
2. On the upper tube, where the Bosch buttons are, it's kind of skinny and doesn't "look" like it would be a fit for one of the new Bosch inframe displays, but, without too much complication, would Orbea support/ able to add the new in-frame display?
3. Should she just use her phone via the Flow app (save us money)?
Appreciate any input/ advice, especially as this is our first Bosch Gen 5 (I have a Bosch Gen 4 via Cannondale Moterra which has the Kiox 300 but no eligible, Gen 5 only, to add the new inframe display.
Bosch makes a retrofit kit for the Kiox 300 and 500. They are available with mounts for either 31.8mm (road and some MTB) or 35mm (MTB) bars, which puts the display out front. You'll need to choose the right mount, and the right cable length for the conversion.
I know of no retrofit kits for top tube displays. That doesn't mean that it can't be done, but will most likely require a trip to a Bosch dealer.
