2020 OptiBike e-bike mountain bike R15C
875 Miles
Bike/components work as they should.
Bike is currently set up for 5-5” to 5-9” rider.
This thing is amazing! Will easily do 35 mph on the dirt and has the suspension to handle it. Only selling as I inherited it and really can't use it like it should be used.
$9000 USD
From Website:
Full Carbon Fiber Frame
Full Carbon Fiber Swingarm
160mm Suspension Travel Front and 220mm Rear
Motocross Style Progressive Rear Suspension Linkage
Removable 52 Volt 31.5 Ah (1600 Watt Hour) Battery (38% larger than old R15)
1650 Watts Continuous Power
2500 Watts Peak Power
190 Newton Meters Torque
27.5 Inch Wheels. Up to 2.8 Inch Tires
Road Legal as Class 2 Electric Bike in Power Levels 1, 2, 3
Offroad Only in Power Levels 4 and 5
Carbon Fiber Battery Case
The all new 52 volt 31.5 Amp-hour battery is housed in a carbon fiber battery case that fits seamlessly into the carbon fiber frame. The battery can be removed from the left side for quick change or service of the electronics.
We put every design detail we learned in the last 20 years of building electric bikes into the R15C
Suspension for Any Terrain
The R15C has a Fox Factory 36mm Fork on the front, with a Cane Creek DBcoil CS Shock in the rear. Total rear travel is 220mm and the travel is very progressive due to the motocross style linkage on the swingarm.
Fox Dropper Seat Post
There is a Fox Factory Dropper Seat Post so you can change seat height on the fly.
27.5″ Wheels
The R15C now has 27.5 inch wheels for better handling and reduced rolling resistance. The tires and rims are wider for better traction.
875 Miles
$9000 USD
From Website:
27.5″ Wheels
