This tread is where to show others a tool and to talk about its use. What do you like about this tool? What is not so great. How do you use it?
I like that it is heavy duty and has a padded grip. I use this extendable ratchet to remove and install bottom brackets. Having extra leverage is very useful.
Remember that the drive side is reverse threaded! Both sides tighten in the direction of pedal travel under power.
Now, we will go beyond anal;
Pair your charger with a "Kill A Watt" device.
1. Get real time charging wattage
2. Accumulates electricity used
3. Provides the cost for usage
4. Among other data
Pretty blue tools 1/2 : Pinion lockring tool:
2/2: this weird Park Tool TH-3 driver:
As far as I can tell it is only really useful for bottle cage bolts.
4. Among other data
all you need for that is a smart plug anymore. my window ac unit does it.
I've got a Watt hour meter that I never did bother to install,..
It could show me if my 25ah battery actually is 25ah, and it will show me accurate real time power consumption while I'm riding so I can keep track of how fast I'm draining the battery.
I don't really need it anymore because I carry a second battery now and I don't have to worry about running out of power.
It would be nice to know the actual capacity of my batteries though, and to keep track of their decline in capacity.
A smart plug on my charger, combined with the Watt hour meter on my e-bike, would show me how much energy is wasted converting house current into ~48 volt DC e-bike power.
I don't like those multi tools they tend to be too short and not easy to use snce their shape sucks.
One thing that I like about the multi tool is that all the bits and pieces are connected, so I can't drop them or lose them.
Except the spoke wrench of course, but it's threaded on quite a ways, so it won't unwind itself and go missing.
I've got my multi tool tethered to my jacket so I don't have to worry about it falling out of my pocket.
I pulled over once and leaned over to check something and it slipped out of my pocket.
I tethered my Leatherman tool as well. It cost me $76 CAD and I don't want to lose it.
Kind of depends on the tool. A lot of the cheap ones have a real short reach and are made of soft metal and bend badly when you reef on them.
The Crank Brothers and Pedros tools are better made and usually have a longer reach. The Park Tool ones are also pretty good.
Pet peeve: a lot of these tools have an 8mm hex key but it isn't strong enough to crack a pedal. What would you possibly use an 8 for on a bike other than pedals?
My ebike came with a multi-tool and it's a cheap piece of crap.
It's better than nothing at all though and worth carrying it with you if that's all you've got.
I'd probably crack my hand if I tried to remove a pedal.
I think that my Crank Brothers tool would survive though ??
My center stand has an 8 mm bolt, but almost no clearance for the multi-tool.
I could probably spend ½ an hour snugging up a loose bolt, but I wouldn't be able to tighten it.
yes but they are still more work to get into places. so these ratchets are faster and smoother and yu can put in more torque. my only complaint is the bits are loose so you have to be careful not to drop them and it may take two hands to put pressure on the tool to keep it in the screw
,.. my only complaint is the bits are loose so you have to be careful not to drop them
I've got all the proper tools at home and prefer to use them over the multi-tool, but I have the same problem with bits or extensions falling off some of my ratchet handles.
(the little spring loaded ball bearing is shot.)
My old torque wrench is the worst where the ball bearing fell right out, so I put a piece of tape over the square attachment point then force the socket on.
I meant coming otu of the screw t=year. rachets are not as good as t handles for that job. but I can convert that ratchet into a t handle so that's really good. I don't usually have to do much of anything while riding though.
Well, the results of a tool is assigned for the new Amazon show called criminal it's not out yet though
well the results of a o
that means you need to reseatt the tire. and make sure the bead is even. or its a crappy tire.
I thought I'd update this thread and let everyone know that you were right, and I needed to reseat my tire.
I took a closer look at the alignment line on the tire and noticed that it was off my a mm or so on one side of the tire, while being off, in the opposite way on the other side of the tire.
I reseated my tire using soapy water this time, (like you're supposed to anyways. Duh,..) and the tire was Dead On!!
I then had to retrue my wheel again to get everything right.
So now,.. my wheels are perfectly true AND balanced!!
I did notice a wobble when I spun up my rear wheel leaning over on the kickstand, but then I realized that it was the half quart of Flat-out in the tube that was causing the wobble.
The Flat-out self balances though after a few rotations then it's as smooth as glass.
You have to start with a perfectly balanced tire before you add the Flat-out though, or the wheel with never be balanced and you can't balance the wheel until the Flat-out is removed.
