Mike leroy
So, spitzing are the performance specs as the gold standard to compare other bikes against.
How does the Grace One.15 Pro ($8500) compare ?
right but is that the motor specs, or the specs while pedalingVmax: 75 km/h
0-50 km/h: 7,5 sec. 0 to 30 mph in 7.5 sec
I think pedalling .right but is that the motor specs, or the specs while pedaling
7.5 seconds isn't bad, but I'm sure the stealth could beat it (consuming 1kw in the process haha)I think pedalling .
The grace one.15 seems like a good alternative to the spitzingSo, spitzing are the performance specs as the gold standard to compare other bikes against.
Yes, almost twice as fast, I believe. Spitzing not so quick.7.5 seconds isn't bad, but I'm sure the stealth could beat it (consuming 1kw in the process haha)
I think spitzing is for the 45mph racing scene. 35mph is all I want to pay for.The grace one.15 seems like a good alternative to the spitzing
Yes, that was very cool. I'm working with it right now.Did you notice what I did in the Google sheets? I pasted Court's review into the Google sheet so you could make your own rating, based on the same info.
Does that help you?
I've seen the grace pro, but they haven't advertised a grace 15 pro yet as far as I'm awareAre you willing to spend $8500 on a Grace 15 Pro? I think the base model with shocks at $6000 is a better deal.
Well it's all about how easy it gets to the 45 mph and how efficient it is.I think spitzing is for the 45mph racing scene. 35mph is all I want to pay for.
You are correct. $5300 for the One.15 . That seems like the best deal. The spitzing is good because you have an idea for how much that. Extra performance costs.I've seen the grace pro, but they haven't advertised a grace 15 pro yet as far as I'm aware
that is an incredible deal, I'm just worried how the thing would do on a trail. last thing I would want is the bumps causing a connection to come loose since there is no suspension.You are correct. $5300 for the One.15 . That seems like the best deal
You can add one as extra. That is why I called it the Pro. I would go with shocks.that is an incredible deal, I'm just worried how the thing would do on a trail. last thing I would want is the bumps causing a connection to come loose since there is no suspension.
Still not sure if the grace 15 will be available with shocks. hopefully.. still a hard tail thoughYou can add one as extra. That is why I called it the Pro. I would go with shocks.
Fork Grace Rigid Fork, Rock Shox Domain RC
