First ebike, and so many choices. Some brands offer multiple sizes (eg. S,M,L,XL), others just one size. Most size discussions start with height and weight. When I bought my first bike, frame size was a common parameter. With ebikes, I seldom find a frame size listed. More frequently, a diagram is posted with a long list of parameters (see image below). But which of these is critical? Many comments suggest work arounds to obtain a proper fit, when the factory configuration is not optimal. For example, a longer seat post, stem risers, longer/shorter crank arms, etc. In my mind, max seat height and reach seem to be most critical. But, if I choose a smaller frame (weight consideration), and then add a longer seat post to attain proper leg extension, this puts more weight on the rear and less on the front. Just this one modification could lead to steering problems (less weight on front tire). What are your thoughts? Thanks for your comments.
