Gionnirocket
Well-Known Unidentified Member
- USA
- City
- Y. O.
Not that some of what you say doesn't hold true but the Maxima wax is in a carrier solvent that flushes out the old lube and dirt and allows it to flow into the chain and then solidify. So I'm not sure how much if any of the previously applied wet lube remains.I posted this in another thread but I've had good success with a very uncommon method of chain maintenance. After cleaning the chain with kerosene, I use a wet lube on each link. After a few minutes I then hit the chain with maxima chain wax. My thought is that the chain wax sort of seals in the wet lube. I was laughed at for posting this but I'm enjoying over 2,000mi. on a 9 speed chain with an ultra motor that isn't babied. I'm right at .5 on several different chain checkers and will replace the chain soon, not sure I want to wait until .75 but we'll see, I could get another 1,000mi. out of this chain
Also your Ultra results if not ridden overly abusive are common.
And lastly in my experience chain wear isn't straight line... It can hold as new for say 2000mi... and then slowly reach 0.5 by 2500mi. But from that point it's a quick slide to 0.75 and 1.0, probably before 3000mi.
ymmv
