Hoverboard Ebike build bldc motor wiring question
neber kenezer
Canada
Yes, providing you connect the Hall wires in the right order, relative to the three phase wires. Since that controller has self learning, it should be able to work with any wire order, as long as power/ground are correct on the Hall plug..
Typically, you connect the two learning wires the first time the controller powers up. The motor should spin briefly forward. Then you disconnect the learning wires, and the next time you power it up, everything should work,
