Benjamin James
- Canada
My bike has been saddled with some factory imposed limitations, I'd like to eliminate those limitations if possible. (go faster). At the moment, it has a Shengyi DGW25pxx family's motor run at 500 watts for a 20" wheel - but rated for 750 watts. The OEM controller gets it's speed signal from the motor and not from a magnetic speed switch on a wheel. The stock controller won't allow me to defeat the speed limitation of 32 km/hr - and I'm certain there's a bit more there. It used a torque sensing BB, which also imposes some additional challenges regarding changing the controller. In addition to that, the OEM battery uses some sort of handshake from the controller to enable the battery (battery has 5 terminals). I'd much like to change out the stock controller for something that doesn't impose so many limitations, but it looks like there's a couple potential snags.
1. I'm not sure about the motor connector pin-outs, and Shengyi isn't returning messages - Would the on-line diagrams of the J610 connector on the motor be consistent from motor to motor (with the exception of the 9th conductor being used for either a thermistor or for a speed signal depending on client?)
2. How do I get my OEM battery to work with an aftermarket controller if it needs to be told to "turn on"?
3 I'd likely be forgoing the smoothness of the torque sensing BB for the universal convenience of a Cadence sensor, as there's no way for me to know how my OEM torque sensor works
4. safety switches on the hydraulic brakes would have to be compatible with the motor cut-out circuit
I'd still need to limit my current to a value that wouldn't cook my motor
5. I realize I'll likely have to mount the new controller outside of the frame downtube, even though the OEM controller is hidden inside.
This will be my winter project, but I'd love an opportunity to establish some dialog with people who know this stuff better than I do.
