Fast n' Furious
- USA
- City
- San Diego
https://www.alibaba.com/product-det...offerlist.normal_offer.d_image.42d31c375uTOvJDoes the link F n F listed take you to a full suspension model of Titanium bike?
I was addressing racks. But Ti full suspension? Sure!
Titanium is as strong as steel but 45% lighter, and twice as strong as aluminum - but only 60% heavier.Oops...just googled Ti weight vs aluminum. I was one of the people who assumed Ti was lighter than aluminum.
Assuming you're still full steam ahead on Ti, what has you want it for a bike frame @Fast n' Furious ?
I posted it for the FS folks information. I had considered these machines before hearing about WW. They are quite stunning.Thanks for posting that Fn'F. That looks like a frame I could get excited about having built up.
I looked back through a bunch of your previous posts but am still not clear I understand your current focus. Do you mind sharing are you still headed toward a Watt Wagons Ti build in hard tail? Or where are you at on bike plans now?
Thanks again.
Is this frame TI or Aluminum?Titanium is as strong as steel but 45% lighter, and twice as strong as aluminum - but only 60% heavier.
So Aluminum, requiring more mass to achieve the same strength as Titanium is definitely heavier.
Unlike Aluminum, Titanium alloys have excellent high cycle fatigue strengths as opposed to their tensile strengths.
Both have have excellent rigidity and flexibility, but the tensile strength of titanium is much much harder than gold, platinum or aluminum.
Titanium, a refractory metal is also highly resistant to heat and wear.
Corrosion resistance? A stable, substantially inert oxide film forms on Titanium's surface, providing the material with outstanding resistance to corrosion. Whenever fresh titanium is exposed to any environment containing oxygen (why I'm dumbfounded at 'painting titanium'), it immediately acquires a thin tenacious film of oxide that confers on the material its excellent corrosion resistance. If sufficient oxygen is present, the film is self healing and re-forms almost at once if mechanically damaged.
An Alloy frame requiring much more material to achieve the same relative strength, with more mass has reduced flexibility, and because it is thicker, unlike the Ti bike, flexing it risks fracture.
Proper Titanium welds are actually stronger than the material being welded - but Aluminum Alloy welds are the weakest points.
Example: I weld a 3' x 6" piece of 1/8 Aluminum to a 2' 6" piece, end to end. Now I pick up the ends and bend them together. Aluminum will fail at the weld. Titanium will fail at roughly the 3o'clock point.
To achieve the proper strength, Aluminum welds need to be much thicker. Titanium weld need only be a fraction the depth.
My understanding is that Aluminum is far more difficult to weld of the two because of heat conductivity. The thicker the puddle required to achieve specified strength in that area, the faster it hardens at the bottom of the puddle, causing a half molten half semis-solid rearrangement of the crystal state - like a fault - in the weld. Also, as it cools it oxidizes - part of the weld. Never does this happen w/ Titanium, but as I've chuckled over and mentioned a failure in Argon shielding leads to a bad weld contaminated w/ TIO2.
So to avoid the above puddle cooling, the heat conductivity requires heavier welders ... and the spread of much more heat to the parts they are welding destroys the Aluminum's temper for quite some distance from the weld. Titanium is not subject to these effects.
A crack at the bottom bracket is a death sentence for an Aluminum G510. Cheaper to buy a new frame. The weld will be weaker than the surrounding metal, now also weakened by losing it's temper, so the crack comes right back.
I place a lot more confidence in bare metal where I can see the welds, than sanded down, bondo'ed over and painted defects.
While I admire them, I've decided an FS bike is overkill for my needs, out of my league and I couldn't use my panniers to shop.
Oh yes. Full steam ahead and damn the torpedo's. My next machine will be Titanium. Didn't decide that after I arrived, I came here looking for it.
I'm fine with the external battery. Internal cables would be swell, but fatter tubes means thinner walls, and or price hikes and added weight. Also, I can't see it with stiff lined hydraulics - but what do I know.
There are a number of FS G510 Alloy frames with enclosed Dorado, even cable routing if one prefers.
That’s what I thought. Would love a frame like that in TI but not sure I want to know the cost.When I expand that picture and push in on it a caption comes into view, "Direct factory aluminum alloy...."
I don't think you can make extrusions like that with titanium.That’s what I thought. Would love a frame like that in TI but not sure I want to know the cost.![]()
Somebody 'splain to me like I'm five: Is there any real reason to put that swoop in a top tube? To me a straight top tube looks so much better.Titanium is as strong as steel but 45% lighter, and twice as strong as aluminum - but only 60% heavier.
oh@reed scott Boy-part clearance!
-BB
To be honest Merle, I'd much prefer a rear hub drive and a Pinion 1.12, but there's no hub that can compete with the G510's powerful endurance - esp w/ the WW's X1 controller, which I'm hoping will pull up a 20mi long, 6 - 10% grade (SL to 1800ft) paved bike path and not thermal trigger. I intend to find out.Thanks for posting that Fn'F. That looks like a frame I could get excited about having built up.
Thanks again.
