pushkar
Typical front wheel axle is 100mm wide.Help a noob out. Please someone define 'boost' as used here. I've often seen this term in regards to bikes and have no idea what it means. Thanks
Boost spacing is (typically) 110mm wide.
1. Spreads out the load over a slightly (10%) wider hub thereby making the wheel stronger.
2. Boost allows you to put a wider tire on the hub while retaining good control. (typically up to a 3.1/ 3.2 inch)
