Dmitri
Hi everyone! Just wanted to share the results of an experiment I did -- putting a fatbike wheel into a non-fatbike fork of my R&M Delite.
As you may or may not know, the choice of forks for fatbikes is really limited: there's basically Manitou Mastodon (the best option), RockShox Bluto (the OEM option, legs are a bit thinner) and a few exotic ones. Those forks typically have 150mm hub spacing.
Well, it turns out that a 3.8" wheel can happily fit into a 27.5+ fork such as Fox 34 27.5+. What this means is that you can put a 26/3.8 wheel in there (or, theoretically, 27.5/3.8 though I haven't tried this as it is an exotic size). Here's what it looks like from the outset (images are clickable):
![20180810_140751.jpg 20180810_140751.jpg](https://forums.electricbikereview.com/data/attachments/24/24680-241c6b567115cd6cf6bdb19799ce9649.jpg)
As you can see, the size is the same as if you had a, say, 27.5/3 wheel in there, so the angles are undisturbed. Now, in order to build this wheel, I basically took a 110mm SRAM X0 hub and laced a wheel with a 80mm DT Swiss fatbike rim. That's it. The tire I've put on is Bontrager Hodag (26/3.8).
The amount of clearance on the sides of the tire is about 4mm on each side as can be seen here:
![20180810_140810.jpg 20180810_140810.jpg](https://forums.electricbikereview.com/data/attachments/24/24681-03a88c1db73b9f362a9abc2dbe9fa72a.jpg)
Naturally, this kind of wheel is incompatible with Pletscher R80 mudguards that I had on, so that had to be removed.
It's not all rosy though! The 80mm rims were never designed to be used with 110mm hubs, so the angle of the spokes can catch the brake caliper on a 180mm rotor. The contact is minimal, but it's extremely annoying, which is why I've filed away a bit of the caliper using some sandpaper:
![20180810_140820.jpg 20180810_140820.jpg](https://forums.electricbikereview.com/data/attachments/24/24682-deea7e7d59c681a9431644a46cd25572.jpg)
The solution to this problem is simple: install a 203mm brake rotor! Not only does this solve the problem of scratching spokes against the caliper, it also makes perfect sense because, with such a (comparably) heavy wheel, you need more stopping power.
So, what are the advantages of this approach?
(Ahh, I wish R&M would do a Delite with a 4.0" rear... that would be the ideal ebike. I can keep dreaming though, right?)
- Vastly improved cornering
- Front wheel absorbs even large stones/objects with ease
- Suspension is superlative... I can drive directly into a curb and the bike just floats over it
- You get to use one of the best, most configurable forks out there (sorry, but it's just way better than Bluto/Mastodon)
- Spokes can scratch against your brake caliper (depends on brakes, obviously)
- A 4mm clearance isn't sufficient for one of those plasticky mudguards... you'll need a fullsize fatbike mudguard with those cateye fork holders and everything
- You need to build what's a fairly non-standard wheel that won't be reusable in other bikes
- If combining with an 'ordinary' rear wheel, now need to pack two different tubes when traveling
