Cable actuated hydraulic caliper upgrade
It is very important to have a olive setting tool when cutting new hose.
Choose your olives carefully.
They are not created equal.
It all depends on what you're making,..
Make sure the hose is tight when you put in the barb and screw the olive so all the fluid stays in when pumping the reservoir on top.
I haven't used mine yet.
I replaced the funnel I broke with one that has a brass coupler, but I still haven't made a brake line.
Maybe I should break my brakes, so's I can make new brakes?
I've got enough brake line for a 40 foot cargo bike. 😁
Another application for cable actuated hydraulic brakes are BMX stunt bikes. They will do things like take a jump and spin the handlebar four times before landing. Can't do that with hydro hoses.
Now that’s cool. I hadn’t even thought of that use case, PedalUma. Absolutely right. Do they make BMX bikes with disc brakes these days? I must admit, I am way out of touch. My kids were riding BMX bikes 30 years ago… That’s the last interest I had.
The big problem with rim brakes is that the braking surface is close to the ground. So, they tend to get grubby. Also, good disc brakes keep the pad very close to the rotor - helping keep out funk. Also, rim brakes suck when they get wet. And if the wheel is out of true or dinged. IME riding bikes for almost 50 years, disc brakes are superior in every way to rim brakes - especially on heavier e-bikes.
I'm not sure what a "hydro brake" is,
Here we go,..
I want a proper electric bicycle with electric brakes so I can fly by wire.
I want an AI powered ebike that I can ride remotely from the comfort of my rocking chair. 😁
I want a rider-less ebike that I operate from my chair.
Something like this, but a full size ebike instead of a drone. 😁
No trikes either.
Gotta keep it real. 😁
No trikes either.
So far only trikes or maybe some self balancing prototypes.
Teleoperated E-Trikes (Emerging Technology)
A more advanced form of "remote operator controlled" e-bike involves a human operator driving the vehicle remotely, similar to a drone. This technology is in development for specialized uses.
  • Ride-Sharing & Delivery: London-based firm Trilvee has developed a system that allows a two-seat Carver Electric three-wheeled vehicle to be driven remotely by an operator. The concept is that a user can request a vehicle via an app, a remote operator drives the empty vehicle to the user's location, the user then drives it manually to their destination, and the remote operator takes over again for the next delivery.
Your link took me to the dark side.
I ain't goin there. 😝😁
This is a specialized test post to see if my post also turns into a link to the dark side with Darth Vado,.. 😁
I seriously looked at the haul st/lt but the force took me to the radwagon 5 where the empire has struck a fatal blow to its father.
I've got a blue link in my post now too.
I didn't do that.
The AI bots are watching us. 😁
I'm posting Bafang now to see if it turns into a link,..
one thing about these cable brakes is there is not the capacity to dissipate heat like on regular hydro's so if you need lots of braking, they are going to be an issue.
The rotor dissipates most of the heat and aluminum calipers heat sink into frame. Even the steel cable would dissipate heat. However I avoid using the brakes as much as possible plus no long descents and with short rides heat is never an issue for me.
Probably even better than mineral oil inside a plastic brake line?
I remember practicing some emergency braking and burned my finger on the rotor when I touched it afterwards.
There was no noticeable heat coming off the plastic brake line.
