DaveMatthews
Dave's not here. Cheating since 2018
- Canada
So far, I have not experienced that with my bike. What sealant do you use? I'm on regular Stan'sNow if they plugged less with sealant it may be worth the effort.
Muk-off was the worst. right now I am using Peety's its like stans but will seal larger holes and works with CO2 plus it does not dry up much at all.So far, I have not experienced that with my bike. What sealant do you use? I'm on regular Stan's
Interesting.Muk-off was the worst. right now I am using Peety's its like stans but will seal larger holes and works with CO2 plus it does not dry up much at all.
both muck-off was really bad about it. Now I grease them with sil icon grease, and they don't plug anymore.Interesting.
When did you start to encounter valve plugging? What were you using, the Peety's, or Muc?
It's just like a Schrader valve. A slightly protruding pin in the centre that you can depress with a fingernail or tool.What is the procedure for letting the air out from the wheel, Dave?
Interesting tip!both muck-off was really bad about it. Now I grease them with sil icon grease, and they don't plug anymore.
it works great. I have not had a plugged-up valve since.Interesting tip!
Another, if you use a compressor is to always give a blast of air in before checking pressure or releasing airInteresting tip!
My experience has been that by the time the valves get plugged by sealant a lot of sealant has dried inside the tire in interesting shapes which don't do much to protect you from punctures. I've never had a case with a sealant-plugged valve where I couldn't easily remove the valve and clean it in about five minutes.Now if they plugged less with sealant it may be worth the effort.
For the next little while, I'll pack a Presta core in my trunk bag, just cuz...My experience has been that by the time the valves get plugged by sealant a lot of sealant has dried inside the tire in interesting shapes which don't do much to protect you from punctures. I've never had a case with a sealant-plugged valve where I couldn't easily remove the valve and clean it in about five minutes.
Now, for an existential crisis, try losing a valve core somehow when you don't have a spare.
That's the thing: I will get plugs with fresh sealant; sometimes, I would only fill the tire a few times. but it was worse on the tandem as it would sit more. So far I have not had peety's dry up. but my tires seldom go a year between changing them.My experience has been that by the time the valves get plugged by sealant a lot of sealant has dried inside the tire in interesting shapes which don't do much to protect you from punctures. I've never had a case with a sealant-plugged valve where I couldn't easily remove the valve and clean it in about five minutes.
This guy tries a whole bunch of different pumps...Installation and pump use on some tubeless MTB tires. He didn't try very hard to get a seal with his pump's Presta head. But the Clik adapter screwed into the Shrader head worked flawlessly.
I’d still like to hear about pump gauge accuracy with vs without the head adapter. I read differing opinions and it was hard to tell which were based on experience and which were assumptions.This guy tries a whole bunch of different pumps...
Did that just before my ride today. Just got home.I’d still like to hear about pump gauge accuracy with vs without the head adapter. I read differing opinions and it was hard to tell which were based on experience and which were assumptions.
