I can understand that.
That said, I do not have a huge fleet of bicycles, I just have one. And if this innovation works, life will be slightly less of a PITA.
Good Presta valve tip, but I just don't understand all this emotion over tire valves — and especially against Seth. I find him reasonable, careful, knowledgeable, and experienced. Here he presented the pros and cons of all the valves he covered.Everybody in my community uses Presta valves (tubed or tubeless), and no one reports issues with the type. Any modern sporty bike comes with Presta. I myself have never experienced any problems with this type of valve.
It is so sad to see how a reactionary influential youtuber is gaslighting his viewers. According to Seth, you shall ride the 3x drivetrain, use Schrader valves and at best convert your existing MTB into an e-bike using Bimotal system. Now, you feel compelled to try the Click system.
I asked YouTube to never show me that stupid face again.
If Presta were so hopeless, it would be no reason for the industry to provide any expensive bike with this type of valve. Guys, please be reasonable.
The best YT comment:
@sjanzeir
1 day ago (edited)
Here's the thing: most people think that in order to inflate a tire with a Presta valve, you're going to need to unscrew the valve nut all the way out. Nothing could be farther from the truth. In fact it is doing just that - spinning the nut all the way out - that gives the air chuck/pump head the leverage to bend the valve stem as you attach it to and detach it from the valve. As soon as I realized what it was that I was doing wrong and stopped opening the nut all the way to pump up the tire, I no longer had any issues with bent valve stems. You only need to spin the nut out about one and a half to two turns to get full air flow through the valve and into the tire.
None of the fifty guys in this picture had anything else than Presta on their bike. I helped one of them to replace the inner tube during the ride.
Presta valves are over 100 years old. Sure, they are a good design, and relatively simple. But to suggest there's no room or need for improvement on a 100 year old device makes no sense to me. Ebike? Who needs it! ABS in your car? Bollocks! Electronic shifting? Bah Humbug! VOIP instead of copper landlines? Poppycock! Etc...Good Presta valve tip, but I just don't understand all this emotion over tire valves — and especially against Seth. I find him reasonable, careful, knowledgeable, and experienced. Here he presented the pros and cons of all the valves he covered.
Besides,
(everybody does it) ≠ (no room for improvement)
Same. And Seth is entertaining. Not my favourite but he's a good presenter.Good Presta valve tip, but I just don't understand all this emotion over tire valves — and especially against Seth. I find him reasonable, careful, knowledgeable, and experienced. Here he presented the pros and cons of all the valves he covered.
Besides,
Internet? Smartphones? EVs?Presta valves are over 100 years old. Sure, they are a good design, and relatively simple. But to suggest there's no room or need for improvement on a 100 year old device makes no sense to me. Ebike? Who needs it! ABS in your car? Bollocks! Electronic shifting? Bah Humbug! VOIP instead of copper landlines? Poppycock! Etc...
That's just me...
I'll only worry when I have to install an app and have a subscription to put air in my tires. Correction: I won't worry because I'll get rid of them in that case.The main argument against Clik as a long term industry replacement is that it seems to be a proprietary, patent protected standard. Hard to imagine the industry as a whole jumping onto it when they have to pay Schwalbe to license the tech to actually produce anything, even if its technically superior.
We're talking about tire valves here. A (mostly) inexpensive part that is easy to swap out if you don't like 'em.
Mine should be here next week.Any indication that the clik valves will be more resistant to sealant plugging than standard presta? I do like the looks of their other properties: no fragile core to bend, better pump head sealing and better flow rate. I thought Fillmore were the answer until I looked at them before buying and realized there’s no way to check the sealant level through them. I use the dipstick method and never have the mess or hassle of unseating the tire just to see how much sealant is in it.
I see that they sell just the clik cores or a complete clik valve that includes the core. It doesn’t look like there is anything unique about their matching valve, but if anyone tries one, I’d like to hear!
To be clear, the review I posted was from a user on a different forum. Will share my experience.These sound really awesome! I'll see if you like them as much in a few months, and then probably take the plunge!
I don't... quite understand Stefan's issue with complaints about Presta. And of course I ride Presta; I go tubeless on almost everything, and I've been riding Presta / Tubeless since 1972.
And... of course they are a pain in the ass. Dave summed it up most of it really well:
<< This inherently is inclined to leak (through the thread) and by wiggling to the side as you try to clamp on a fairly short length of thread. The thread also slowly chews up the rubber seal. You also have the extra step of tightening (or screwing on) the pump head. >>
In my experience, this has always been true, and has been true on every bike I've owned. I would only add that some valves seem to be consistently a bit better than others, or possibly a little better than what Dave describes, but not much.
And some are much worse! When I went tubeless on Mercury, my LBS-- who has been great with all other things-- used some kind of psychedelic-oil-sheen colored extra-long valves that blew the cores out about every 20 times I filled them. I'd hear a hissing sound getting louder, and then roll over immediately, covering the dog with my body and my head with my hands right before a loud BANG as the valve core shot out and hit something that wasn't me or the dog. (It became like a drill, and we got pretty good at it.) No other valves have done that so consistently, though I had one or two other tires that did it once only.
I also disagree about unscrewing the valve cores. The valves on Seeker have to be unscrewed almost all the way to get air into the tires; it's just the geometry of the particular adapter, valve, and pump. And I've never bent one or had any leakage from those particular valves that I view as being abnormal for tubeless tires, which always deflate a little faster than my bikes which (briefly) had Schraders. I've been using the same valves for over a thousand miles. They work fine, they're just a PITA, so it these would save me five minutes of trial-and-error of fiddling when I fill the tires, I'm all in!
Fear not... thou shalt hear the truth from an actual user.I'm biting my tongue and fingers![]()
