Being relatively new to ebikes and the mid-drive BBSHD I have, I'm seeing a pattern with the advice given here on this forum and elsewhere. And mind you, this isn't a complaint...apparently just the nature of the format. It appears that many, maybe most, of the ebike forums are more pavement, commuter, dirt road, etc. focused than more aggressive mountain biking, and I kind of get where that's coming from.
After riding our demo Trek Rail at the shop I work at part time as a mechanic, the bug bit me hard to convert one of my better, older MTB's...an '08 SC Nomad...to a mid-drive. After only a couple of outings, I am hooked. I'm sure I will be able to reprogram some improvements into the software, but it was quite rideable the first time out. It's a little abrupt in its initial power delivery when hitting the pedals again, but I'm also used to riding dirt motorcycles, so that's not a totally alien issue.
While I'm sure I will be able to tailor my motor's program more ideally with time, I was hoping to find more experienced, trail oriented suggestions on these different forums to not have to start from scratch. I've done a lot of reading but have not found a lot of data. That Karl Gesslein fellow is pretty informative, but most of the info I found from him on a true MTB application involved the BBS02 version. I'm posting this here as it's designated as an MTB use category.
So...anyone know of good, specific, mountain biking program numbers on the HD from any source? I'm not looking for the so called "hot rod" programming that seems to involve sheer speed and such. I want to retain power, but I'm looking for slightly smoother, predictable power delivery.
