Pre-Waxed Chain
Robspace1
After trying many chain cleaners and solvents and still not able to remove all the factory grease off my new ebikes chain, I gave up and bought a pre-waxed chain from Vital Chains. Well worth the $50.00! I use Silica Super Secret for add on wax after a few hundred miles. So far the chain has stayed real clean and really quiet. This saved me so much time and hastle.
What I usually do in an insulated bottle is put the chain in and some of the water-based degreaser, and then pour in boiling water and shake the hell out of it. This works pretty well. But the last KMC chains I got— maybe it was because of 12 speed— this didn’t work at all.
I could never get all that oil off. It kept coming back and mixing with the Squirt wax. Big mess. This chain is real clean and works great. The Silica Super Secret is overpriced though.
More importantly, how long will the chain last/ how reliable is it? I have +8k mi on a kmc e8 chain.. so I'll deal with a litte shmutz.
But maybe try a two step process. WD40 seems to remove factory goop_lube quite well. Then simple green seems to remove wd40 easily.
Wd and Simple Green both failed to completely remove the factory grease from my chain. Whatever lube they put on my new ebikes chain was real good stuff but a bitch to remove. The pre-waxed chain from Vital Chains is Shimano. So far it's working great. All ebikes should come with waxed chains. So much better/cleaner then oil.
Perhaps it works better on the KMC factory lube. Just spraying wd on seems to remove a lot of lube. Curious how did you use the WD40 and simple G?
I haven't tried it yet but I did purchase a new chain and some paraffin wax and was going to make it a bored winter project. My plan is to soak it in wd40 overnight in a warm place like on top of the boiler, then wipe it off and use compressed air to blow it dry into an old towel. Then perhaps do the same with the simple G and rinse with hot water.
I didn't soak it overnight. I used both products and scrubbed like hell for 20 minutes, then hosed it off. Repeat -I did that plus tried a bike chain solvent and it still had grease hidden in it. I thought I had it all off but when I put the wax on and rode it the next day, it was a sticky dirty mess. I gave up and bought the new pre-waxed chain. I should have done that first. Price wise it comes out about the same as buying a chain and all the cleaning supplies and the time needed to clean it. For $50.00 it's worth imo to just buy one already waxed and ready to use.
Finish Line didn't require cleaning. On my first bike, my chain was grimy after 450 days of daily use, maybe 2,000 miles. I wiped the chain with a paper towel, applied the lube, and wiped again. Then the chain stayed clean on the outside, so I'd wipe only after lubing. I'd wait a day because wiping too soon removed rust protection.
After thousands of miles more, with very few applications, the chain was still very clean and quiet. I was sure there was still hidden grit. I put layers if wire mesh in the bottom of a plastic coffee can, coiled the chain on it, covered it with gasoline, and waited 20 hours, shaking occasionally. After letting everything settle, I hung the chain to dry, removed the mesh, and carefully poured off the gasoline. When the residue dried, it was a soft reddish powder, like cocoa. I didn't feel any grit at all. Somehow, the Finish Line had not only kept grit from sticking, it had displaced the grit already there. I put the chain under tension and measured 11 links with a caliper. It was still tighter than the nominal 1/2" pitch.
That dry lube has done very well on two other bikes. I intend to use it on the bike I just bought.
Did a quick Google and it seems there are better choices than wd and Simple Green. Especially in that simple G can damage the steel if left soaking.
Seems mineral spirits followed by acetone or alcohol (isopropyl or denatured) is what most people do.
Thanks for the heads up 🙃
Yea, I tried alcohol also plus wd40 chain cleaner. Nothing got it clean. It looked clean but inside it still had factory grease. I didn't soak it all night but it was easier to just replace it with the pre-waxed chain. The new one stays super clean. I just added more Silica Super Secret wax as I was riding in the rain and had a few hundred miles on the new chain. It ran great today. Smooth as silk!
I think your process is flawed, not the solvent. People do it all the time, including Vital Chains. It's not rocket science, but the small details probably matter.. Like soaking with agitation, not scrubbing.
But hey if buying it done works for you, no problamas. Not cleaning it and just using Boeshield T9 has worked well for me. I hardly ever handle my chain anywho and it works without issue... 8k mi and counting.
I was going to try the preclean and wax as a winter keep busy project.
mmdv🙃
The time spent and materials needed to get these chains cleaned then waxed is a waste of time and money. Much easier, faster, and cheaper to just replace the damned thing. But, if you just enjoy doing it as a hobby, go for it. Spending hours cleaning, soaking, rinsing, then rewaxing is more expensive and time consuming then simply buying a new one.
I spent 5 hours cleaning and waxing my new E8 chain, but I was farting around and wasting a lot of time.
I'm going to be rewaxing my chain again, but it will only take 10 or 20 minutes.
I just wash it in the sink with hot water and dish detergent, then dry it and into the melted wax.
No need for a deep clean the second time around.
I'm LOVING My Waxed Chain !!
I've got dual chain rings on my ebike with no derailleur for them.
I just pop the chain onto either chain ring by hand.
No fuss, no mess.
I actually put my mid-drive in PAS 1 that is set to about 4 mph.
I was coasting at about 15 mph with the chain moving 4 mph and the pedals stationary.
I reached down and guided the chain onto the the other chain ring with my bare hand will coasting, and quite effectively changed gears without stopping or getting my hand caught in the chain wheel.
I would Never do that with an oily chain.
Not because it's Stupidly Dangerous, but because it's just too damn messy. 😁
So, which is better? 5 hours working on a chain to clean, soak, dry then wax, plus the cost of cleaners and wax or spending $50.00 for a new one that's been triple dipped in high quality wax and
ready to use? I tried option1 but went to option two. Some factory lubes are harder to remove from the chains then others. My last ebike chain was easy to strip and wax. My new ebike chain had some super lube on it.
So, which is better? 5 hours working on a chain, or spending $50.00 for a new one that's been triple dipped in high quality wax and ready to use?
I spent $45 each for my two E8 chains, but didn't know that there was a prewaxed chain option available, or I would have bought that.
Do you happen to known if there is a prewaxed E8 chain available?
It's a KMC chain, and I don't know if there is a prewaxed version available, or if there is another Super Strong 8-Speed Ebike chain available that comes prewaxed?
Well that's one issue, the E8 isn't available pre-waxed. I can use an E9 but that's a weaker chain and it's $68 shipped. I purchased my E8 chain for less than $30 on Amazon... Though right now they're not available. As far as what's needed, I have all the chemical cleaners mentioned above already (some for over 20 years) and a pound of paraffin was $6. I really don't see the major effort needed to putting it in a jar and letting it sit for a while and occasionally shaking it. Going into this blind is where the OP failed. Working harder, not smarter would discourage most.
Also keep in mind that the pre-waxed treatment at best last 400mi before you have to apply a maintenance coat... Of which I will continue to use T9 (wax).
X8 chain is available but that's $39 shipped for a >$18 chain
A clean chain is nice... But I'm not going to pay a mark up >125% for it because I'm not smarter than assembly grease 🙃
Most chains sold on Amazon are fakes. Buy from a factory store or a reputable third party bike shop seller like Bell's.
I often do.. but when I got mine, Amazon was the seller. Like stated above it now has +8k mi on it. I think some of that has to do with the 1 - 1 of an igh. The Shimano chain that came on the bike lasted 2500mi.
That said.... KMC is running a great sale. Just picked up two e8 for $53 delivered!
Now when I try the strip/wax treatment I will do both plus an X8 at the same time. Curious to see how the X8 compares durability wise, plus I just like the two_tone look. 🙃
@PCeBiker... Thumbnails! 🤣🤣🤣
I got lucky and ended up getting two real chains from AliExpress.
I actually only bought one but it hadn't shipped in almost two weeks and the order was going to be canceled and refunded in two days, so I bought a second one.
Then then they both ended up being shipped.
Then I bought a third chain and it Did turn out to be fake!!
See if you can spot the error?? 😁
