REVIEW: QR-E 250W ELECTRIC BOOSTER BICYCLE MOTOR AND B60i AND B70 BATTERY
New Qiroll H70 battery arrived!
Finally i need to replace my 4 year old H70 battery..nothing wrong still works but sag 2 LED blue bars (voltage sagging) when i ride just doesn't have that "OOmmpphh!" power like it used to recently this month. However consider this old battery have been survive for 4 years with everyday bike commute use to work and daily charging i was amazed it still hold up today without dying. Old battery still alive hopefully i'd get extra lifespan until next year. Kudos to QIROLL for making quality battery while my other e-bikes battery died within a year for triple the price.
As for new battery i bought last week (fast shipping): Qiroll H70 it looks like an improvement over the old ones with different cap color and added proper user label. I'm planing to get another one after i do some rigorous battery test this week. Btw thanks to QIROLL again for adding extra goodies inside the box: Free switch cable (Actually my old ones was wreck) and also Quick release adapter (Also i need it for my folding bike)....i didn't ask for it but it seem that they can read my mind across continent, lol! Awesome gift pack.
Hope this new battery give me another 4~5 year of riding longevity. :cool:😍
Photos:
New battery tested, felt like super human again. Gonna order 2nd one so i could daily rotate its usage.
Hi everyone,
I recently printed a batch of high-quality stickers for the Qiroll H70 Lithium-Ion Battery Pack. I printed extra copies, so I’m offering them to anyone in the community who might need one
Sticker Details & Specifications:
  • Dimensions: 85 mm × 120 mm (designed specifically for the H70 casing)
  • Finish: Premium matte lamination (durable, scratch-resistant, and weather/water-resistant)
  • Adhesive: High-tack permanent adhesive
  • Design: Replicates original battery specs table, safety warnings, and technical data clearly.
Price: €12 / $13 USD each (Standard worldwide shipping included)
Shipping directly from Germany 🇩🇪
Payment: PayPal
If you're interested, drop a reply here or send me a Direct Message (DM) with your address!
Cheers!
If not ALLOW please delete!
I've sent this email to Qiroll but would like others opinions. (On another topic, here is my unboxing of this kit:
I've had this kit for a few years now and everything is still working great. The only issue I have is with the friction layer. I recently applied my last friction layer and it came off after only a few miles. The adhesive separated from the rubber part. So I've been using the kit without the friction layer. Seems to be working fine. What are the long term effects of not using the friction layer? Seems to me that there might be slightly more wear on the tire but I can't imagine the hard surface will wear very much since the tire is much softer. And maybe that the tire will slip more easily since the coefficient of friction will be lower? Please let me know if I may continue to use the kit without the friction layer.
Without the friction tape you'll lost lots of torque..you may not feel it but it slips a lot even when dry but super worse on wet roads like 0 torque. I ditch the stock Qiroll friction tape 4 years ago and go for 3M flooring friction tape (those looked like sandpaper surface) gave me powerful 1:1 ratio torque without slipping. Within 4 years of use i don't see my tire worn off because of that sand paper 3M tape, the road surface is far more abrasive than that friction tape. Still use the same rear tire for 4 years until i decided to upgrade because of the rubber started to rot at sidewall due to hot sun over years of use. I love riding Qiroll in the rain.
Hi everyone,
Payment: PayPal
Cheers!
This sticker is very useful if you traveling on board planes because they need to know battery ratings capacity before allowed on board.
Good that it works so well for your use. I only ride for recreation or exercise, not to get anywhere fast or without getting sweaty. For me - on a flat looking route like yours - I wouldn't even bother with any assist. I want/need assist for hills/climbing and my Qiroll Mute and Pro just couldn't deliver adequately for me, no matter how much I wanted them to. In fact both were making clicking noises and otherwise malfunctioning before I retired them both. Another brand friction drive motor unit I tried overheated and seized within <10 miles of use on a long 6-10% grade while I was putting in a lot of effort pedaling. My Yamaha mid drive, TSDZ2 mid drives have thousands of trouble free miles in much more demanding use. Horses for courses.
Clicking noise? Is it happened on Mute or Pro unit?
The Mute developed a regular clicking noise and drop in power, very little magnet resistance spinning the motor compared to before. The Pro suddenly lost power on a ride and wouldn't restart despite battery not being drained, after that episode it has worked but intermittently clicks. I wonder if they failed due to overheating on hills (which is everywhere I ride and thus the reason I bought them). Neither has been used in some time, not reliable for my use - good to see that it works so well for you though.
Edit: Forgot that the Pro also emits a high pitched whining sound at times, also forgot that my son tried it out a few months ago installed on a Dahon Jack 26" folder, he wasn't impressed.
New to the forum, just wanted some information, I got the qiroll max, wanted to see if anyone knows anything about it or compare to the qiroll pro.
That Pro with whining sound i knew very well happened on my Merida (white bike), is it continuous? Mine like that, sound like jet turbine engine when throttle. I suspect the clutch mechanism inside making some scratches or something. Happened twice on same Pro unit. My other Pro so far was silent. I can't comment much on the clicking noise for MUTE and lost power on Pro since i haven't encounter such. Did you contact Qiroll support?
I got there test demo version before they called it MAX, i did some comparison back several page in this very thread forum. It consume more power and good torque when climbing hills. Its a good unit but i don't like the size and weight. Just heavy and wider than Pro. Good use on heavy duty bike.
Ah I see, do you know if there's any changes since the demo version? And whats the range you were able to get? Im mainly gonna be using it for university commute probably around 13km one way, just wanted to see if I can make it either one way or both way with minimal pedaling if i dont need to.
Furthermore I was reading over the thread and just wanted to make sure, do u put the grip tape over the included friction layer with superglue or is do u put it straight on the roller without the smooth friction layer?
Yes on the "jet engine" sound from my Pro. They're both now a few years old so I'm not hopeful for any warranty support. I just need to move on from Qiroll or any other friction drive and stick to what has proven to work for me.
For the MAX (400W) 13km x 2 way should be no problem. Hefty amount of power left inside H70 battery. I put my 400W (MAX) on my folding bike just to scoot around the town with zero pedaling.
I don't put the Qiroll original friction tape..that tape fail me. I use 3M grip floor tape as previously recommended directly over the roller but since its wider than PRO unit i have to layer 2x side by side. No need super glue unless two ends of the tape tips flaked out.
Well, have to live up to the jet sound if you wanted to continue using it unless you can send to Qiroll for engineer inspection. I'm sure they can help out.
Thanks but it's not worth my time to pursue, let alone cost of shipping even if Qiroll was willing.
