PCeBiker
No-Hands No-Pedaling No-Credentials
- Canada
Just found this ...
That It !!
That's exactly what I was thinking of doing, but didn't want to bugger up the seals.
I'm glad you posted that before I removed the IFP Valve Cap.
Just found this ...
So overloading with grease may not be a good idea as it can clog the equalization/balancing port.
I wouldn't do it.. You'll damage the seals and your not fixing the issue that caused the imballanceOK, that all makes sense now.
My can wasn't pressurized so it just unthreaded and stayed there.
When I push the can on, it pressurized the lower chambers.
I wouldn't think that jamming a feeler gauge under the seal would be a recommended procedure, but whatever?
No not the problem... But also not a good ideaI don't think that's the problem.
You can't install the can without pressurizing the lower chamber.
Just found this video...
But in my case it doesn't solve the problem as it returned after 50 miles or so.
Coolio... It's a quick fix.
Now with the new articles and videos I'm thinking the $20 / 50 hour service should be all I need to do.
,.. it doesn't solve the problem as it returned after 50 miles or so.
... think of this.
Even if you end up with the shock under negative pressure on assembly. You should be able to exercise the shock thru full motion and it should equalize.
Just like when you pressurize it to proper sag and then exercise thru full motion to equalize the chambers.
The equalization of negative and positive pressure refers only to the air can and I believe that it happens thru the aircan dimple with positive being above the part called seal head/air can, and the negative being below.
So in my mind the release of pressure with the feeler cures the symptom but the cause still remains unless it was a one off fluke.
Keep this in mind.. Much of the crap on youtube and other s*it people post as fixes are one off that never have any follow up. Kinda like in this thread if I didn't return to state my fix was a fugazi. I think most are too embarrassed/lazy to post updates. I'm thinking the same for the post that said load it up with grease... Which may be why you had problems.
Another thought is just disassembling a shock with seals that have heavy use is enough to cause them to fail. They were OK until messed with.
So is your shock working correctly?
