DaveMatthews
Dave's not here. Cheating since 2018
- Canada
Awesome to hear about the customer support, and glad you have it sorted out!I got my Clik valves and after a glitch have them installed and working well. First, the glitch:
I got two valves and the pump head replacement with the adapter that can be used independently. I tested one valve out on my tubeless tire and it leaked at the pump head connection. I pumped the tire up but watched the pressure drop on my pump gauge when I stopped pumping. I removed and reinstalled the Clik, fiddled with the pump and pump head but still had a leak. I emailed Clik describing the problem and they replied within hours saying they were sending me two new valves, a new pump head adapter and some aluminum valve caps. A++ for customer support!
The new ones came today and I put them in and it works perfectly! I’m using the head adapter in my standard presta/schrader pump head - push it in, flip the lever up and use it that way. That makes it easy to use my pump on other presta or schrader valves - just flip the lever down and pull the Clik adapter out.
I’ll try the first batch of parts again when I get a chance but I think it may have been my error. The Clik valves thread into the presta body but then need a full revolution or so using the supplied tool after finger tightening. I’ve learned the hard way not to cinch presta cores in too much so I may have not put the cliks in tight enough.
My biggest irritation with presta has been connecting the pump cleanly so the tire doesn’t lose a bunch of air, either when I put it on or when I take it off. It’s always a pretty iffy process for me. First world problem.
The Clik adapter snaps right on without losing any air. And it unsnaps without losing any either. Seems like a winner!
The next time I replace tires I might try muc off big bore valves. Those look like they solve other tubeless issues: 250% more flow for seating tires, no clogging and no leakage at the pump head. Until then I’ll use the cliks.
Interesting to hear about clogging issues. Can't say I've had any on Presta or Clik... yet...
