@Bitmugger thank you for your answer.
Actually, I forgot to mention that I already got myself both 48V 25Ah and 52V 20Ah batteries from Jenny/Aijiu. I am happy about how they are performing, and I was just genuinely curious to hear what is the acceptable true measured Ah range of these batteries.
So,
@tomjasz I am not in a hurry to get an answer from Jenny. I can wait as I am not in the middle of buying new battery at the moment.
According to test reports my 48V battery has 23.81 Ah, and 52V has 19.12 Ah (if I read it correctly, as the last number written was not wery clear). Not as much as
@Bitmugger got but ok. Actually that is quite near to that "in spec" value of  4753mah. If that is the minimum requirement for Samsung 50E, then my battery is quite close to meet that.
One thing I could have hoped to be different was, that I would have wanted bigger BMS. Even just 40Amp instead of 30. I am not sure, but if someone can confirm: Is there room in the case to even fit bigger BMS than 30A? If there is, then I suggest to make it possible to choose between different rated BMS versions with these batteries.
