Just found this on one of the european sites (deals from Spain) - was this already mentioned in another post? I can't remember. Looks like the tero x is the purer eMTB breed than the cross-breed the tero started out as.
Get Specialized Turbo Tero X 4.0 29´´ NB 2023 in Silver for 2573.99 $. Ideal for bike with fast delivery. Buy MTB bikes at Bikeinn!
www.tradeinn.com
Good idea, but as a self-appointed Tero beta tester I have this input:
1. The motor would be perfectly adequate but range would be limited to less than 30 miles in hilly terrain with this battery. I get about 30 miles in my area with a 710wh battery without being concerned about making it up the hills to get home (using Eco as much as possible and Off down grades/hills). This battery has 25% less capacity. So “you’re gong to need a bigger map” might apply to the Levo SL but not much else.
Engine: Specialized 2.0E, 50Nm Torque, Custom Tuned Motor, 250W Nominal
Battery Specialized U2-530, Alloy Casing, State Of Charge Display, 530Wh
2. With that cassette and a 29” rear wheel, a 44T chainring gives very nearly the same ratios as the current Tero. Since this is a mullet it could use a 46 or even 48T (havent checked in with bikecalc.com yet). But as designed (38T), this is still going to be a mid 20’s mph bike.
Groupset
Rear Derailleur: Sram Sx Eagle, 12-Speed
Chainrings: Sram X-Sync Eagle, 104Bcd, 38T, Emtb Specific, Steel
Cassette: Sram Pg-1210 Eagle, 11-50T
3. Why a mullet? This bike isn’t going to appeal to the shredding downhill market anyway and a smaller rear wheel has more downsides than benefits for an XC (bigger map) bike.
Wheels
Rims: Specialized 29, Hookless Alloy, 30Mm Inner Width, Tubeless Ready
Tires: Front: Specialized Ground Control, Grid Casing, T7 Compound, 29X2.35 // Rear: Ground Control Grid T7, 2Bliss Ready, 27.5X2.35
4. Rack for panniers but no horizontal mounting surface?
There have been plenty of times I felt rear suspension would be beneficial but as spec’d this bike isn’t going any further and only a little faster than a Levo, so I don’t see the benefit here. All that said, I’m sure it will sell.
