Thanks! That's what I assumed, but this video for a Vado SL showed them doing it clockwise to remove, so I got confused https://electricbikereview.com/foru...-bike-turbo-vado-sl.33777/page-11#post-283941Lefty tighty/righty loosey on bike cranks both sides. So clockwise for the left crankarm bolt.
Are you sure about that?Lefty tighty/righty loosey on bike cranks both sides. So clockwise for the left crankarm bolt.
See my post above where I answered this. You’re right for pedal threading but not for SRAM self-extracting crank arms.Good question I have no expertise in removal of crank arms but I think it's counterclockwise to TIGHTEN port side and clockwise on the starboard side which is the drive side.
Where is @Stefan Mikes can you answer this man?
Yes. The bolt is to hold it to the splined shaft and serves dual duty as a crank arm puller. Pretty cool setup.Okay crank is splined?
Here ya go. Callaway Gardens (GA) xmas light bike night ~3 weeks ago.This thread is resolved then.
Show of where you ride your ebikes.
Thanks! Yeah, I think it was you thread that I saw earlier that suggested it came off the other way!Are you sure about that?
Cuz the left crank arm on my 2022 Vado 4.0 loosed counterclockwise.
@Nonlinear see my post in this thread: https://electricbikereview.com/forums/threads/turbo-vado-crank-arm-removal.49175/
not yet! I had to order a Park Tool torque wrench, and have been travelling for work, so I'm planning to do it this weekend when I get home!@Nonlinear: Have you managed to install the PearTune?
I've installed Peartune 4.0 on my 2022 Vado 5.0 IGH so I can confirm that you just need an 8mm hex bar and turn anticlockwise to take crank off.not yet! I had to order a Park Tool torque wrench, and have been travelling for work, so I'm planning to do it this weekend when I get home!
Thank you! How is the Peartune working for you by the way?I've installed Peartune 4.0 on my 2022 Vado 5.0 IGH so I can confirm that you just need an 8mm hex bar and turn anticlockwise to take crank off.
I received Peartune V3 but was able to exchange for V4 as this is what I had asked for. It's very easy to fit, and plenty of room in the housing to tuck it away. The V4 allows various setting options via a sequence of button presses. It's working well and as I had hoped - the 15mph for UK was a bit limiting! The bike is easy to get up to a steady 20mph now and with a little extra effort to 25mph without the assistance cutting out. After a longish ride, once you come to a stop there is a lag in the speedo settling down to zero as if playing catchup - if that makes sense. I just use the bike for getting from A-B.Thank you! How is the Peartune working for you by the way?
Hi, I've now installed the peartune, but cannot figure out how to activate it! Could you tell me what buttons you press to do this? Thanks!I received Peartune V3 but was able to exchange for V4 as this is what I had asked for. It's very easy to fit, and plenty of room in the housing to tuck it away. The V4 allows various setting options via a sequence of button presses. It's working well and as I had hoped - the 15mph for UK was a bit limiting! The bike is easy to get up to a steady 20mph now and with a little extra effort to 25mph without the assistance cutting out. After a longish ride, once you come to a stop there is a lag in the speedo settling down to zero as if playing catchup - if that makes sense. I just use the bike for getting from A-B.
Thanks for your quick reply! I did press the walk button for 1 second, and it just kept saying 0. But after playing around with it for about 30 minutes, and watching their YouTube video, I found out that I can press F1 (the top button that controls the light), and then I can press +-+-+-+-+- (10 times). Then the TCD displays a 10, which I assume is the maximum speed setting, and I was able to change the number there to 45 kmh. At least, I think I changed it, I wasn't able to actually test ride it as we have a storm here right now.Press the "Walk" button for 1 second. You should note the TCD will temporarily display "speed" 5.6 to indicate it is enabled, if the display reads 0.0 then it is not enabled. I set mine as enabled by default when turning on the TCD. If you need to change any of the defaults, the correct sequence of button pressing is vital and not as intuitive as the instructions suggest, let me know if you need any help with that!
View attachment 144272View attachment 144273
Hi, thanks again for your advice. I commuted into work this morning, and just wanted to follow up.Press the "Walk" button for 1 second. You should note the TCD will temporarily display "speed" 5.6 to indicate it is enabled, if the display reads 0.0 then it is not enabled. I set mine as enabled by default when turning on the TCD. If you need to change any of the defaults, the correct sequence of button pressing is vital and not as intuitive as the instructions suggest, let me know if you need any help with that!
