Canada to restrict class 3 ebikes to 20mph
Did I miss the post where it explains how an update is done to an ebike "over the air"? I don't have a "smart" ebike -- I don't have "smart" anything in my house. Except my laptop will get those danged Windows updates without my permission. But it is connected to the internet. Are these Stromer ebikes connected to the internet? Do you have to have Bluetooth enabled in order to ride? I guess I don't understand how it is done...
Although I do not know myself, I thought I read that the Stromer has a SIM card like a smartphone to connect to the cell network.
There is a good story somewhere in this Forum...
That anti theft Stromer is the good side of external control.
It can bite you in the butt though…
Did a 74 mile ride and at the end at ice cream social I moved the bike 40 feet to another spot.
Bike was off and it went into theft mode…. Rear wheel gets locked by intentional motor resistance
and I didn’t have code number on me to release🙁
4 block lift rear , push , rest, repeat. Load in car.
Then it strikes me….if that had happened 35 miles out at rest stop, that would have really sucked.
It was his problem, not the Stromer's?
I generally am against any "anti-theft mode" as I know myself and am sure my e-bike would prevent me from stealing my own e-bike :) Still, the story of the NY guy was one of the best I have ever read here!
After consideration and technical analysis with some technical friends, I think we have a solution for some of the Canadian Stromer owners.
If you managed to turn off your Canadian based Stromer, before November 30th, 2022 to avoid the forced Canadian firmware and your bike remains off, this may work out for you. Kill the SIM card, before turning on your Stromer. The Stromer OMNI-C controller is based on a Sierra Wireless radio model HL-8548. There is an embedded SIM card (eSIM) that you can find on the board. There are many YouTube videos out there that can show you how to heat up the SIM to soften the top and pull out the SIM. This should leave the Radio intact, looking for a cel tower, without an IEMI/SIM to authenticate on the network.
Upon more consideration of this possible fix, it made me think of something as an owner of two Stromers. We should be able to ”opt out” of any connectivity for my ebike. If you do not want to be tracked, the dealer should be able to disconnect any ebike from cellular connectivity upon delivery. It’s a basic right to ask not to be tracked, however, this would also discontinue the alarm service that is included from Stromer and no ÔTA OS updates would be possible, unless you could toggle the SIM service on and off manually for software updates only. If you want to track your own bike without Stromer knowing, just use an Apple AirTag or TILE system, as you wish.
I am considering my options moving forward, I look forward to hearing if anyone out there killed their eSIM and if their Stromer continues to work well without cellular connectivity, which I assume will be fine without a SIM. I heard from a friend this week, that a Canadian owner of a new ST1x was throttled down to 32 Kph on Nov 30th, as he was on a ride! The bike “just started offering less assist” during the ride and he called the dealer to find out about the ÔTA update was today… poor guy and he had just bought the bike.
Any other Canadian Stromer owners running into problems, been affected or are looking for a fix? Please post! Keep your Stromers OFF, until a fix is found. More news shortly.
Sounds good! I hope this works for you.
Have you done it or are you waiting to see if it works for others before trying?
Shouldn't Stromer charge a low 799$ fee for their owners to enable them to change their CA address to a temporary US address ? Seems only the ebikes connected to a canadian address will
be affected.
Optional : 1599$ Platinium permanent address change .
ENABLE PPAC ?
Press yes/yes.
US Stromer ST5 for sale. Only 500 miles.
Golden US address included😀
$5,400
See want ads.
28 mph
Minnesota but can deliver close to Canadian entry city….
It does suck that Stromer is now forced to comply with crazy CA law. 🙁
I wonder about just shielding the SIM. I was thinking it was more like death rays from space. Canada is so huge that there must be many unpopulated areas without cell service where the bikes would continue to work just fine.
once it gets the "upgrade" it can't be reverted back. I would have disc. the Sim by now or connect a Sim card with a US address ?
What if every SIM that is within earshot of a Canadian tower gets the message. That would be easiest. No need for registration data or serial numbers. That would be a mess. Numb and Number. Simple. Like a PSA it keeps flashing the local update. Some in the MI U.P. might get hit but that is collateral and could be appealed case by case. Occam's razor.
I believe updates are reversible, not by the riders though. Stromer seems to have the CA option in all of the the previous firmwares. But the option to switch to non-CA was open to the riders via service menu and seems that is what the sellers did when selling these bikes.
Now with the new firmware that option is removed and the riders are locked to the speed limit of the country they are residing in. I understand how the previous owners feel, I hope there will be a solution for this. However this is not only Stromer's problem, their firmware already had the CA option, the dealers have a greater role in this.
Some positives about Stromer's cellular connectivity:
1. It is a fantastic anti-theft device, by far the best among the ebikes on sale today. In cities like SF where bike theft is notoriously high most of the Stromers are recovered.
2. It is a great system for firmware updates. You don't need to deal with taking your bike to a lbs because they have a crappy encrypted dongle to get a necessary update.
3. The error codes can be checked via cellular connection rather than having the need to take it to a lbs.
@Petropoliskhan: It looks the thread title should be: "Stromer restricts their Canadian e-bikes to conform to the existing laws".
A simple thing: Stromer was delivering illegal e-bikes to Canada; someone in the authorities has realised that and requested Stromer to conform to the law. Fortunately for Stromer, they can do the OTA update.
In my opinion, Stromer has acted unethically, in bad faith and unlawfully toward owners who relied upon representations and descriptions that the bikes, as bundled with certain firmware, are capable of 45km/hr. In violation of consumer protection legislation available in most provinces, Stromer then unilaterally imposed a firmware update limiting these bikes to 32km/hr, without the knowledge or consent of owners, a practice that deceived and misled consumers. Stromer was under no obligation in law to interfere with current owners’ private use and enjoyment of their bikes but did so to appease authorities who control the company’s ability to import/sell new bikes in Canada. To accomplish this conversion, Stromer violated its own privacy policy, as well as Swiss law, by using owners’ personal information and data for an unauthorized purpose; specifically, to identify Canadians’ bikes and restrict their performance, ostensibly, on behalf of Canadian authorities.
So now you know:
"Below are universal rules across the provinces in Canada regarding electric bikes (excluding Prince Edward Island, as they have their own set of rules):
  • Motors are limited to 500 W output, and cannot travel faster than 32 kilometers per hour on motor power alone on level ground"
Specific rules for BC, Canada:
Chap, you can protest to Stromer until you're blue :D
I would recommend doing a deeper dive into the source Regulations. As a starting point, the fact a motor-assisted bike has a maximum speed greater than 32 km/hr simply means it does not qualify for the category identified by ICBC in the above screenshot from their website. Importantly, however, laws/regulations in BC do not ban, outlaw, limit or otherwise restrict motor-assisted bikes from travel on public roadways at speeds above 32 km/hr… but don’t rely on me, please DYOR.
