Tannus airless tires
FWIW posting first ride impressions because otherwise I'll forget:
26.2 miles, a local route that I have ridden dozens of times
2094 feet total ascent
max speed 38.9mph coasting downhill
started with fully charged 48v 10ah btrpower battery, finished with 47.9v per multimeter (47v per display voltage at same time as multimeter measurement, lowest display voltage seen on climbs was 46v which was probably closer to a true 47v)
Tannus states that it takes 60 miles for break in but my early impressions are pretty good, with caveats
compared to previous tires that I never knowingly ran as low as 80psi which is what Tannus claims is the airless tire pressure equivalent;
-they were noticeably quieter running than the Marathon and Armadillo at all speeds
-they seemed to have a overall slightly harsher ride but not noticeable to me on smooth road and not a big deal on rougher surfaces or hard packed gravel
-I used higher levels of assist than usual and increased rolling resistance was noticeable
-top recorded speed was a few mph lower than usual on the steepest downhill segment and battery usage was significantly higher than with prior tires, if I recall correctly I had ridden over 40 miles to drop this battery to 48v in the past, maybe I wasn't trying as hard today and took it easier on the steepest portions but I don't think that would account for all of the variation
- they felt less planted in higher speed (mid 30mph) curves, but again they aren't broken in according to Tannus
what I really liked was just taking off and riding without checking tire pressure, checking to be sure that I had my spare tube/patch kit/pump/CO2 inflator (which I move around from bike to bike), and most of all that I didn't feel the need to dodge or pay as much attention to glass or debris in my path which made my ride feel safer because I was able to concentrate more on my surroundings, especially in areas with close car traffic.
I was planning to do a longer test ride tomorrow but my freehub was skipping so I'll have to take it apart and see if the pawls are sticking. Then family visiting so it will be a couple weeks at least before I have a chance to ride this bike again.
addendum:
today I took my BH Gravel bike (Yamaha) on a slightly longer 28 mile ride today. That bike has Schwalbe G-one 700x40c tires that measure a true 40mm in width, I run them at the max 70psi with Mr Tuffy liners. Much less rolling resistance than the Tannus airless, max speed on the steepest downhill was 43.1mph, a full 3mph faster than the Tannus on my Schwinn Hybrid. I'm not regretting buying the deeply discounted Tannus airless but there is a definite performance penalty to accept in order to get the no flat advantages. Hopefully performance will improve with break in.
Despite their limitations I wonder if this guy, at least at this moment, would have preferred to be riding on Tannus airless tires.
I have a sort of love/hate relationship with them installed on a wheelset.
I just mounted a 26x1.75 Tannus Razorblade airless tire on a geared rear hub motor rim. It was much more difficult than the videos showing mounting of narrow 700c versions. Here is a video that I found that was more realistic for the tire that I mounted.
Looking forward to riding this bike without concerns about getting a flat tire. Patching or changing a tube on a mid drive is easy, same as a regular non ebike but much more difficult with a heavy geared rear hub wheel with no QR or thru axle and a torque arm etc to deal with. and, If you're looking to invest in property, Athens offers a wide range of options to suit different budgets and lifestyles. Apartments for sale in Athens are popular among both local buyers and international investors due to the city's strong rental demand and vibrant neighborhoods. It's a good idea to compare locations, amenities, and future growth potential before making a decision. Has anyone recently purchased an apartment in Athens and can share their experience or recommendations?
Makes sense. The wider Tannus Razorblade fights you much harder than the narrow 700c versions shown in most videos, and hub motor wheels make flat repairs a real pain due to the torque arm, phase wires, sensor cable, and no quick release. That's exactly why going airless is worth the tough initial mounting on a setup like yours.
addendum:
I had a "fattie"(20x4 with knobbies) that beast was about 10 mph slower on the "screamie" hills!(it found a happy owner though-didnt know no better I guess-younger and faster)
