m@Robertson
Merciless (on the inside)
- USA
Eeek. Open up the bottle of FlatOut. You'll find there is a hose built into the top of the bottle cap that you only need to extend. Its sized for a Schrader valve. I use a Presta-to-Schrader adapter and then just press that to the presta valve once I remove the Presta valve core. Then squeeze the bejesus out of the bottle and the sealant roars into the tube at a fast rate. I use the hashmarks on the side of the bottle to gauge how much I am loading in. Not precise but good enough for my purposes.I bought a couple of large 500CC Syringes (included about 2ft of tubing) from Amazon. I will just pour the correct amount in the syringe and “push” it into the tube. Easy and accurate.
Bottom line FlatOut should not need anything additional to get it into the tube. it even has a valve core remover (Schrader) built into the little lid that caps the hose extension.
UNLESS you have a wonky valve. I have actually - rarely - needed to use a meat marinade injector with its long, broadly-opened needle from the grocery store to either a) extend past a rubber flap at the bottom of the valve at tube-level or b) poke a hole into the tube itself to inject the sealant. I used the latter with Slime for the few presta tubes I owned with non-removable valve cores. If doing the latter you can either let the sealant seal the tube or do a proper Rema-type vulcanizing patch over the hole you just made.
