Using Flat Out in smaller tires questions
I recently purchased a Trek FX+ 2 ebike with a hub motor and am mortified at the thought of getting a rear tire flat. The bike comes with 700x40 tires and as such, as a first step, I have ordered a pair of Swarlbe 700x38 (I assume the tires will fit on the 20mm rim) Marathon plus tires and am strongly considering adding Flat Out as well. My question is, in reviews, I see tests where it is added to big fat ebike tires but wondered if effective with smaller tires as well. If you have small puncture with the small tube and tire, will enough of the sealant effectively ooze out and plug the tire or more importantly, plug the tube? Also from viewing the Flat Out web site, they recommend using 8 oz for 27.5" and "less than 2"" wide tires. 38 mm is considerably less than 2", it seems like 8 oz is a lot of sealant, should I really be using that much?
Does this combination of tires and sealant offer a very high probability of not getting a flat? Do I really need to consider adding a liner such as a Mr. Tuffy as well? On my road bike I have Continental Gatorskins but although not often have still gotten flats.
You probably solved this two years ago, but for anyone else dealing with hub motors: 8oz is overkill for 700x38c tires.
