m@Robertson
Merciless (on the inside)
- USA
Slime can clog a tube. So can FlatOut. But to get that result you have to use it wrong. Any time you have tire sealant of any kind inside of a tube, you have to rotate the air valve to the upper half of the arc of its circle (think of the valve as sitting at 1' o'clock. Definitely no more tha 3'o'clock). THEN you put air in or bleed air out.Not doubting anyone else's experience, but I've used Slime for years and never had a hint of a clogged valve. It shouldn't take a lot of air pressure to blow any Slime out of the valve if some did get in there. And it's water soluble, I can't compare it to other sealants because I've only ever used Slime and it has definitely worked very well for me.
TT
If you don't do that, the goo can clump near the valve and the act of releasing air becomes the same thing as a puncture. the goo near the valve rushes into it. Clogged valve. BUT knowing this, its easy to never let it happen.
