Gionnirocket
Well-Known Unidentified Member
- USA
- City
- Y. O.
I try not to adjust pressure during a ride and at home I always use a compressor to give a quick blast of air to clear the valve before measuring and adjusting.Slime can clog a tube. So can FlatOut. But to get that result you have to use it wrong. Any time you have tire sealant of any kind inside of a tube, you have to rotate the air valve to the upper half of the arc of its circle (think of the valve as sitting at 1' o'clock. Definitely no more tha 3'o'clock). THEN you put air in or bleed air out.
If you don't do that, the goo can clump near the valve and the act of releasing air becomes the same thing as a puncture. the goo near the valve rushes into it. Clogged valve. BUT knowing this, its easy to never let it happen.
