Hi Stanley,Hello,
Anyone have any updated experiences with the QR-E Pro? I have a cargo bike that will be otherwise very expensive to turn into an ebike, and this is looking more and more like a great option.
Thanks!
I installed the QR-E Mute on my cargo Bike (Mono Trio Bike - Old Version) and it works OK.
Some back ground info:
I live in Copenhagen - Denmark - so it is basically flat and paved roads. The cargo bike weigh is around 42 kg. But I carry my girls, so it goes to 64-66 KG plus, my weight 80 KG. Total: 144 - 146 KG. And you know, a 3 whee l bike has an increased drag (friction).
I decided to try using the B60 battery, just to test it out. The range is around 7KM, not sure. The QR might slip, when the wheel is wet. I am considering buy another QR Mute (for my other bike) with 2 B70 batteries.
But overall it's a simple solution, if you need a pedal assist. Its a bit hard to install in a Cargo Bike, due to the position - It might be good to use a jack or smth.
The QR Pro probably can give you a better boost, but I guess it depends on the load and terrain where you live.
