Merle Nelson
- USA
Wow, that's not bad if it's shipped by months end. Good for you.
Wow, this is awesome! I did some preliminary research, but this looks like super complete guide. Thanks!In case you have not already seen this, there is a detailed user post about Kindernay wheel building
DIY Kindernay XIV gear hub installation
DIY Kindernay XIV gear hub installation Finally I have installed the Kindernay XIV gear hub kit Kindernay ┃The most advanced, high-speed, internal gear hub┃ on my 2018 Haibike xduro allmtn 6.0 size S and today I am going to went thru the process so you can see what you need to to in order to...www.emtbforums.com
Finally got the proper sprocket - ready for the wheel building! Hope Kindernay won't break their promise...
Nope. I plan to replace Enviolo Hub on my Gazelle C380+. Regarding front sprocket, it is 55 tooth. Will check exact model tomorrow.Are you BBSHD? What's your front sprocket..???
In US. Will let you know how customs goes. I did order bike parts from Europe earlier, but never anything so complex or expensive.@ava1ar, What country are you in?
If in the US, I will be very interested to find out if the Hub clears customs with DHL, or if you have to take a broker.
I will also be interested in finding out any fee taxes or duty you have to pay to get it through.
Please let us know!
Thanks for the link!They have the bleeding process on their channel
Yes, exactly like this. This is clearly visible on the photo I posted few days back.Can you confirm that when you look at the left side you see, 7 screws on the periphery for the Cage, and 6 inside for the rotor, and one of the 7 is aligned with one of the 6.
Chain line....then one day, hopefully, belt line.Next to check the belt line![]()
