Gionnirocket
Well-Known Unidentified Member
- USA
- City
- Y. O.
No worries... You found the problem.You were right.
There is a VERY bad connection between the battery and the motor.
Im sorry that I checked it just now.
Should have been my first thing to do like everybody suggested.
I allready tried contact cleaner but it is still nor working better.
The battery has a seperate charging port.
These problems are common with these builds. The contact cleaner is only a temporary solution, but it helps in diagnosis and is good to use in the future to keep things clean before they go bad.
As Thomas suggested, perhaps something like AFC50 or dielectric grease can help you protect the connections that you need access to. I would make those that you do not need to open occasionally as solid as possible with a butt crimp and then covered with heat shrink that has water proof adhesive inside.
You need to keep all connections as clean and protected as possible.
I asked about the separate charger port as this is a good place to check battery voltage to verify the problem is not internal.
Good luck... I hope you are on the road soon.
