Stefan Mikes
Gravel e-biker
- Europe
- City
- Mazovia, PL
I am on the second Kinekt 2.1 seatpost on my full power Vado. When Specialized LBS was rebuilding my Vado 5.0 into 6.0 per lifetime frame warranty, they could only find a frame size S while the original was Medium. The LBS guys compared the e-bikes' geometry and determined they could use a 450 mm seat-post to get at almost the same geometry, with the cockpit being a tad shorter. So they bought a 450 mm Kinekt to replace the 350 mm original I had on my Vado before (a nice gift!)
However, the replacement seat-post came with the Medium (black) springs, and I am not that a lightweight person. When the Kinekt bottom spring was pre-loaded lightly, the saddle was compressing the spring totally, no suspension action. When the spring was set up stiffer by the adjustment screw, I was experienced severe pedal bobbing. With the spring pre-loaded even more, there was hardly any ride cushioning at the rear of the e-bike.
While inspecting the contents of my "bicycle cabinet", I found a set of Orange (Stiff) springs. It took me some time to dismantle the Kinekt for the replacement of springs, and even more time to re-assemble the thing, even if it looked easy on YouTube instructional videos. I was aware I should be very delicate with the connecting screws. Despite of my efforts, the socket for one of the screws turned out to be damaged, and I had to tighten the connection with Loctite...
The next thing on the next morning was setting the spring pre-load. It basically requires two people. The rider shall sit on the bike with the second person supporting the bicycle as it does not fall aside, and rotating the pre-load screw until it stops. Meaning, the spring is fixed at the position as set by the rider's body weight, and it only will compress more as part of the suspension action. I'm alone, so made it feasible for me. I leaned on the saddle with my forearm with my upper body weight and some extra force, then tightened the preload screw with the other hand. It has worked! (the next step is setting the proper saddle height).
Now, everything is working fine. The saddle does not drop under my body weight, there is no pedal bob, and my backside is properly isolated from the uneven riding surfaces. The seat-post works very well.
Now, you may understand why I prefer the Redshift ShockStop stem to the Kinekt. The only thing to do with the RS is rotating the adjustment barrel to the position per the instruction manual. I have never needed the optional helper spring but even adding the helper spring does not look complicated.
Otherwise, both systems offer equally excellent performance!
