Chopperbill
I ordered a 11t freewheel before my RadRover was delivered. Road it once before I started to install it. Noticeable “hamster” effect. Took wheel off and low and behold the axle nut and washers won’t slide over the wire harness connector. Park tool won’t either. I could have drilled out the tool to go over the connector but no way was it going to go over the nut. Being new on here I couldn’t find a post or a video on the net. All I saw is how easy it was. Only possible way I could see was to take the freewheel apart to unscrew the hub with a pipe wrench. I did that without ruining the hub and collected all the parts in a magnetic bowl so I could put back together. After install I went for a ride. Big difference,
Was thinking this morning I might have been able to use a punch in the hole of the left hand thread of the bearing holder and drove it backwards. Not sure that would have worked because it took a lot of pressure on the pipe wrench to remove the hub. Going to cut a slice in the Park tool to slip it over the wire harness for when I have to do it again.
