Was demoing a Surface 604 and an Elby recently and the LBS tech said that the throttle shouldn't be used under heavy load (as in going up hill). Was made to assist on flatter ground. He said it is too hard on the motor and will damage it.
I am new to biking and not in the greatest shape (yet). I was using the throttle while pedaling with pedal assist when I got tired going up a long hill. Is this incorrect. If range/ power supply were not a concern can you not use just throttle if say your knees need a rest?
Thoughts or recommendations appreciated...
