Nova Haibike
The Park Tool Tire Seater might help, but it is not inexpensive.
Try running soap between the rim and edge of tyre, pump up to about 15 psi and going for a short ride, then pumping up to 70 psi ...
Hi Steve,May I ask what make and model bike they were on and what size tires they were in?
Oh I see, perhaps they are not as useful on the narrower road tires. How does she like the Gazelle? Any serious problems? How many Kms on it now? Pardon my nosy questions.Hi Steve,
I fitted a set to my wife’s 2018 Gazelle Ultimate T10 with Bosch Performance Line, and to my 2018 Merida Espresso 600 EQ with Shimano E8000
Both bikes run 700-35C tyres
Hi Steve,Oh I see, perhaps they are not as useful on the narrower road tires. How does she like the Gazelle? Any serious problems? How many Kms on it now? Pardon my nosy questions.
the Kiil Stop i s fine for skinny road bike tires but it will not go over tires more than 1.8 " wide. Useless on 27.5 x 2.4 tires.A good tire tool is priceless... here is another recommendation for easy tire work.
Amazon.com: Kool Stop Tire Bead Jack: Sports & Outdoors
Buy Kool Stop Tire Bead Jack: Tire Repair Tools - Amazon.com ✓ FREE DELIVERY possible on eligible purchasessmile.amazon.com
the Kool Stop is fine for skinny road bike tires but it will not go over tires more than 1.8 " wide. Useless on 27.5 x 2.4 tires.
I tried to install these and Tubolitos in my 2.6" Schwalbe Smart Sams. Wrestled, literally on the ground with my knees on the tires, using lots of soapy water.
There was NO WAY these puppies were going to seat with one person. I broke one tire lever. So I put in regular tubes.
I have 31,000 miles on my Bosch performance speed Gen 3 motor with no problems.Hi Steve,
You’re right....not nosy questions at all
I’m happy to share
The back story is that I have been riding bikes all my life, in particular road bikes, until my knees said enough
This is the reason I got into ebikes, as I still wanted to continue to ride and commute daily
My experience gained riding light road bikes with low rolling resistance tyres allows me to know fairly quickly when things are amiss, as I found with the Tannus Armour
For this reason, I don’t rate them too highly for road riding or commuting, and have continued with a tubeless setup
I would image for most people who ride casually on paved paths/roads or on trails/gravel, who want piece of mind that they are minimising the risk of flats, wouldn’t have a problem with them
My wife loves the Gazelle and has clocked up 6,000+kms, riding with me on weekends
The only problem to date was the front brake needed to be bled, as it had some trapped air from new
Until my wife got her ebike, she hardly ever got on a bike, which is odd as she is Dutch
Now we are out and about wherever and whenever we can, spending quality time with each other
We are so impressed with the performance and quality of her Gazelle, that I am considering getting the new 2020 Gazelle Ultimate T10 step through when they are available in Australia
See the range of Velo De Ville bikes available at Perth Electric Bike Centre
View the full range of Velo De Ville electric bikes available at Perth Electric Bike Centreperthelectricbikecentre.com.au
That said, I’m currently researching the reliability of Bosch powered ebikes with high mileage
I’m not confident as yet to convert to a Bosch powered ebike for myself given the distances that I clock up
I have discovered mixed reliability results once Bosch drives get 10,000+ kms on them
My current Shimano E8000 powered Merida with 30,000+km has been fabulous, and is still going strong, which gives me a lot of confidence to continue with another Shimano powered ebike
The problem we have in Australia is having enough options and choices for trying and purchasing quality ebikes
Trek Super Commuter | 31,033.9 mi |
1-0 Tannus
I guess I'll take them along next time I need something done. Very expensive stuff not to use, but difficult or impossible to return...
Wrong term. I couldn't get the last 8 inches for the life of me.
Yeah, it's not listed as a size that needs to be trimmed, but I bet it would help. I got everything inside okay but it was very tight.
Well, for now I'm over it. They are on with tubes and I'm happy for the moment.
35mm internal 2.6, shouldn’t require trimming. Was using Tubolitos.curl the armour under, or between the rim and tube
Yup I watched the tech at my LBS struggle and had to get help from another tech. It takes 3 hands sometimes.35mm internal 2.6, shouldn’t require trimming. Was using Tubolitos.
I was at the end and had it all in there. The Armour was all inside (which was tricky). I’m sure most of you have experienced a very tight wire bead where the last 6 inches takes some work. This was about 8-9 inches, and even with my 240lb knees on the tires I couldn’t get even another inch inside with a tire lever, and broke one in the process.
Maybe with a second person, or better tools. Maybe both.
I should mention that even with just tubes these 2.6” Smart Sams were the tightest MTB tires I’ve ever installed. Usually I can do it on a table, but these I had to put on the ground and use my knees.
