For you it may be but if one wants to go on any trails that are slightly technically challenging one should have a bike that is better designed for it. Removing one battery from a SuperCharger or a SuperDelite does not make it a true mountain Ebike.Just because the batteries are integrated it does not mean that one cannot remove some capacity. Some bikes have mutiple integrated batteries and one can be removed when not required. Sure there will always be cases where on some bike, or in some situation, one design might be better than the other that is true of many design choices.
On a bike like the super delight, and given the OPs desire to have a large battery capacity, my experience tells me on board capacity (does not have to be fully integrated) is the best way to go.
It also leaves a gaping hole in the frame. A piggy back second power pack is a far better solution. Also the power pack weighs quite a bit less than a power tube, especially the 625 which is a beast.For you it may be but if one wants to go on any trails that are slightly technically challenging one should have a bike that is better designed for it. Removing one battery from a SuperCharger or a SuperDelite does not make it a true mountain Ebike.
Yes I find the bike handles much better when I am carrying two spares if they are both centered low near the rear axle.If you are going to carry along a battery in a bag, the Ortlieb E-Mate is best for that job. It has a padded internal compartment that carries the battery vertically and separated from all other cargo.
E-Mate
Developed especially for e-bikes, the E-Mate bike bag allows you to securely stow a bike battery in addition to your daily gear.E-bikers know what it’s like to have a (replacement) battery lurching about in their bike bags.www.ortlieb.com
Didn't sound like the OP wanted a mountain bike. I'm advising based on what i understood was being asked, not what i would want.For you it may be but if one wants to go on any trails that are slightly technically challenging one should have a bike that is better designed for it. Removing one battery from a SuperCharger or a SuperDelite does not make it a true mountain Ebike.
Hi @steve mercier , just curious as to why you think this would be a better off road bike? Is it just the weight difference, or are there other factors in terms of geometry (including ground clearance) and equipment that lead you to this conclusion? Cheers.So do I and it works great using my Ortlieb back rollers. I would take this bike with 1 or 2 spare batteries over a Superdelite . If you compared both bikes (with similar tires) this one will handle better off road ,cost less and weigh less.
Yes 25 + 20% = 30I see the Moustache weight is 25.5Kg. Of course, has only one battery, but the Superdelite with one battery weights 30Kg
Hi Jay. No it is more than the weight. If you could test ride and compare a true Emtb you would notice how it can handle trickier passages without the white knuckles.Hi @steve mercier , just curious as to why you think this would be a better off road bike? Is it just the weight difference, or are there other factors in terms of geometry (including ground clearance) and equipment that lead you to this conclusion? Cheers.
Just FYI, there is a cover available that solves the "gaping hole" problem when riding with one battery. I am quite sure that these dummy covers are available for all models with 2-battery integration.It also leaves a gaping hole in the frame. A piggy back second power pack is a far better solution. Also the power pack weighs quite a bit less than a power tube, especially the 625 which is a beast.
Yes tight uphill turns can be tricky. And yes the bike shown was for comparison to the Delites and Chargers as it has lights fenders rack etc. My point is that the Delites and the Chargers are not true Emtbs compared to the Levo ,the Norco Sight Vlt or the Bulls Copperhead or the Moustache Game etc... I am not an engineer but If you compare the wheelbases for example you can imagine how the handling will be quite different. I just checked and the wheelbase on my Charger is 2 inches longer than on my Game 4 ( both size mediums) and almost 5 inches longer than my wife's Powerfly 5 (size small) No wonder her bike feels so nimble.Hi Steve. I ride blue singletrack occasionally on my Delite GX with Fox. It is no mountain bike and I go around jumps and similar technical trail features (I have found air a few times but prefer not to). It does rock gardens pretty good, just not at speed - or at least I am too old and wise these days to go too fast, especially with COVID going on. I can barely get my front wheel up, and an out of control jump would be pretty hard to correct. I was struggling to see how the Moustache shown would be any better other than weight. A Specialized Levo would leave my Delite for dead for sure if I were racing, but I tend to ramble way more than race. However, I doubt there is nowhere my Delite couldnt go at the right speed, except where it would be at risk of bottoming out like going over small logs. Uphill tight hairpin turns can be challenging, but mainly due to the torque on the motor. I love uphill flow tho! Thanks for replying.
Hi @John2911 I am planning to upgrade to a dual battery model - where can you purchase the covers from? Is this something my LBS can order from R&M?Just FYI, there is a cover available that solves the "gaping hole" problem when riding with one battery. I am quite sure that these dummy covers are available for all models with 2-battery integration.
So is that 2 trips? One for the bike and another for the panniers?I just think of all the situations when I had to actually carry my e-bikes in my hands![]()
I would take the R&M suspended rear carrier with panniers with batteries in them over this axle centered rear rack carrying panniers with batteries in them.So do I and it works great using my Ortlieb back rollers. I would take this bike with 1 or 2 spare batteries over a Superdelite . If you compared both bikes (with similar tires) this one will handle better off road ,cost less and weigh less.
