Is there a Specialized page I could have look at this new bike?Yes, I think it’s called the Sirrus Carbon X 5.0
Yes but if it is not posted on Specialized website then it officially does not exist. For instance, I'd like to know about the regional availability.Bikeradar.com has a video on it.
Surprising to hear it! Perhaps the Futureshock could be tuned? Are you a lightweight person or are you on the other side?Not sure my 5.0 SL needs to be any lighter to be honest; despite the future shock it is rigid as hell. The carbon fiber fork is part of the reason I'm guessing as every bump of any size is an impact.
Yes, it does come with optional inserts for the Futureshock so I likely need to go that route at 200lbs/91kg.Surprising to hear it! Perhaps the Futureshock could be tuned? Are you a lightweight person or are you on the other side?
Some interesting observations of mine:
- I use Redshift Shockstop stem on a Vado SL 4. It worked like a dream with a single elastomer piece. After I added Innerbarends, the suspension stem stopped working! I thought to myself the character of my e-bike had changed, so I added the second elastomer piece (as it were drop handlebars). The ShockStop started working again!
- I was provided with a new Kinect 2.1 suspension seatpost as a part of my big Vado warranty repair/upgrade. Soon, I discovered the seatpost seemed not to be working! My brother who rode behind me said: "It looks your own body weight makes the suspension totally compressed since you have mounted the bike!" He was right. I increased the preload on the springs, and the suspension works as intended now.
Is it possible your body weight is compressing the Futureshock so it does not work and the additional spring should be installed there?
I weigh 96 kg/212 lb, and with my weight adjustments need to be done on the suspension pieces I use.Yes, it does come with optional inserts for the Futureshock so I likely need to go that route at 200lbs/91kg.
I could be wrong, but it seems to me the FutureShock 1.5 is supposed to have one of the springs in it, choosing which one based on expected riding/conditions?Yes, it does come with optional inserts for the Futureshock so I likely need to go that route at 200lbs/91kg.
I was watching a video on FS1.5, and there is an extra spring to be installed in the case of need. Otherwise the chamber for the extra spring is empty.I could be wrong, but it seems to me the FutureShock 1.5 is supposed to have one of the springs in it, choosing which one based on expected riding/conditions?
Future Shock
support.specialized.com
Hi Gaj as well as checking out what’s happening with the future shock check your tyres as well. If it’s the pathfinder sport ones they aren’t great for suspension. Bit hard. There are better more supple tyres out there. Also check the tyre pressure, you might have them pumped too hard which will make them feel like concrete. These days the science has realised that with good quality supple tyres we can have bigger volume tyres which the extra air really helps with suspension while being no slower then the high pressure narrow tyres I used race on back in the 80s!Not sure my 5.0 SL needs to be any lighter to be honest; despite the future shock it is rigid as hell. The carbon fiber fork is part of the reason I'm guessing as every bump of any size is an impact.
Can you send me the link?I was watching a video on FS1.5, and there is an extra spring to be installed in the case of need. Otherwise the chamber for the extra spring is empty.
It has one internal spring installed. The other three are optional.Can you send me the link?
I just pulled out my springs from the box expecting there to be two of the three options in there, with the missing one being in the bike, but no, there are THREE springs, soft, medium and hard.
Very very odd that my bike may have no spring whatsoever!
Thanks.
Intersting; the thee springs in the box are "helper" springs that supplement the main spring which is why I did notice some damping but tomorrow I'll try the medium (black) helper spring.It has one internal spring installed. The other three are optional.
I watched this video out of sheer interest:
Too bad 42s are out of stock in the US since forever@Rás Cnoic is right about the tyres. I recommend Pathfinder Pro 2Bliss. These are fast rolling , supple, with excellent grip and durability
Too bad! I have just looked at the Specialized U.S. website...Too bad 42s are out of stock in the US since forever![]()
