I thought about getting one but I need a saddle thats flat end to end and side to side. I may be able to handle a little side to side curve but not a lot.The Selle Anatomica is designed to be used with padded bottoms. If you can't or won't wear them, it is clearly the wrong saddle for you. You are probably better off returning it, getting your money back and continuing your search for a saddle that works better for you without padded trousers or shorts.
Now that's impressive!No padded shorts=Brooks B67. Day in and day out.
Rode 14 miles yesterday. Went out later rode some more. Could ride today but it’s raining right now. I couldn’t do that on a b17 which I have also x 3Now that's impressive!
Are you familiar with the Selle Royal Lookin 3D. It is a firmly padded saddle that is one of the flattest both side to side as well as front and back, that I have seen. I actually have one of them that came on my wife's Riese & Muller Homage. It is one of the men's versions and she wanted a substantially different style of saddle, so it has never been used except for a brief test ride.I thought about getting one but I need a saddle thats flat end to end and side to side. I may be able to handle a little side to side curve but not a lot.
this is The one I use. I need a saddle flat both side to side and end to end. I wish I could find one a bit more narrow. but I can ride 20 miles a day on my commute without shorts on it. the rest I have to use padded shorts.Are you familiar with the Selle Royal Lookin 3D. It is a firmly padded saddle that is one of the flattest both side to side as well as front and back, that I have seen. I actually have one of them that came on my wife's Riese & Muller Homage. It is one of the men's versions and she wanted a substantially different style of saddle, so it has never been used except for a brief test ride.
View attachment 84377![]()
Lookin Moderate
Visible comfort and iconic design. A bike saddle for any type of riding.www.selleroyal.com
it looks cool but it has too much curve end to end and side to side for me. I need a more flat saddle.I will say this. The Infinity saddle is the only saddle that I have ever sat on that gets more comfortable the longer you sit on it. At 100 miles its a lazy boy recliner. It's touchy on setup but once you get it right, there is nothing quite like it. I did not bother trying to solve the range problems until I solved the saddle problem.
hit some big bumps it may just launch you out of the seat (G) if you need that you doing it wrong.Get this inflatable air pillow seat cover...
And mount it to this seat suspension spring.
How much resale discount on an an ass rubbed trade in saddle?Hey this is kind of becoming topical for me because the Ergon SMC saddle I bought last year is getting all squished out and is a lot less comfortable, especially on longer rides. So the search continues. I swapped out to another saddle (Sella Italia Men's FLX Gel Flow Deluxe) that wasn't quite as comfortable as the Ergon.
I'm probably going to go hit the LBS tomorrow and ask about saddles, again. Fortunately they have a deal where you can trade in saddles until you find one that fits...
You'd have to ask.How much resale discount on an an ass rubbed trade in saddle?
Spoken like a person that still has fat under his ischea. Mine all melted off age 63. I still have fat on my belly, but not on my hips where it would be useful. If the nose of the seat is tipped back, I end up sitting on my glands instead of my ischea. Those are still useful, I don't need them crushed.A few tips:
- I find that, for me, the saddle likes to be just a few degrees back with the nose just a bit higher. You don't want to be slipping forward on to the skinny part and find yourself pushing you fanny back and up to be comfortable. Very small adjustments of the saddle angle will make big differences. Lower the nose in tiny increment just until it takes the pressure off your delicate parts. Time spent fine tuning saddle angle will yield optimal comfort.
- Keep the leather properly tensioned. Use a 6mm wrench turned counter clockwise (facing back) to keep the opening between the two side at 6mm at the narrowest part. Use the wrench as gauge such that is slips through using the flat surfaces of the wrench making light contact between both sides. First few rides it will need to be done each time, then every week or so it will stabilize to the point where it will need to be done far less frequently. The black leather stretches a bit less than the other colors and has a harder surface and won't show wears or scratches. Do not use any kind of leather oil or grease on the top. It will allow the leather to stretch more. Just keep it covered in the rain.
- If you did not get a rain cover with waterproofing saddle sauce kit to keep the underside of the saddle waterproofed, it is a good investment in keep the leather in good shape. I highly recommend it. The saddle sauce needs to be applied quite infrequently and is used on the bottom of the saddle and the edges of the leather NOT ON THE TOP. The neoprene cover looks good and follows the contours of the saddle nicely. Just fold it up and tuck it into a saddle bag or whatever kind of bag you use to carry tools, tubes, etc. https://selleanatomica.com/products/waterproof-package
- Did you get the model with the alloy frame or the steel frame? The alloy frame has Chicago screws on the underside going into what looks like stainless rivets on the surface of the leather which allows for a replacement leather, easily done at home with an allen wrench. The steel frame is rivetted.
- Adjust the fore and aft position of the saddle: Make sure that when your foot is on the normal ride position on the pedal and the left pedal is at the nine o'clock position (forward and parallel to the ground) that your saddle is positioned fore and aft, your left knee joint is directly square over the axle on the pedal, straight down perpendicular to the ground line from knee to axle. A friend and a makeshift plumb line (piece of string with a 10 or 12 mm box wrench hung from it) will help you fine tune this.
