I am new to Ebiking, and have two different bikes.
Trying to identify how PAS should function.
On a GoPower Express 750w fat 20" folder, my PAS seems to be related to speed.
‘Once I hit a certain speed, if I continue to pedal, the motor will stop drawing watts.
The speed limit is relational to each PAS setting.
‘This is great when I’m pedaling down hill or over a desired speed to keep cadence but do not want the motor on,
but then want it to kick in if I fall below the desired speed.
Next, I modified an Ecotric Dolphin with a KT Sinewave Controller and LCD 3 (upgraded because the original setup in PAS 1 was too strong at 14mph)
The pas,no matter the level, will always draw motor watts at any speed.
The watt draw is relative to the PAS setting, and incrementally increases with each level.
‘This seems to be more of an on or off system when pedaling.
‘This drains the battery quicker than my other bike, as the bike is constantly drawing power if pedaling.
I am trying to identify both
1. Is there something a miss with one of my bikes on how PAS should work Or are there varying cadence setups?
2. Is there a way to achieve the speed cut off system on my Ecotric Dolphin?
Below are my current settings on the Ecotric with a KT controller(36v48v 20amp)/lcd3 upgrade:
Wheel Size 23" P1 85 P2 1 P3 1 P4 0 P5 15
C1 00 C2 0 C3 0 C4 0 C5 10 C6 4 C7 1 C8 0 C9 0 C10 N
C11 0 C12 4 C13 0 C14 3
