Alaskan
Bumpity for this thread. I have purchased a Nyon 1G version and I'm waiting for my controller cable purchased separately to arrive. I'm running Android on a Samsung S7Edge and would like any coaching available. I do have some family in England that can purchase a Google Play card. What steps should I follow now? Thanks.
@Steve Porter
@Alaskan
Installation of the controller is straightforward. The other end of the controller cable is attached to a 1"'x1" rectangular panel on the back upper left of the intuvia display mount, held in place by four tiny screws. You need an very small, jewelers Phillips screw driver.
One of the Nyon's great advantages is that it will install its updates from the web automatically. It did not have the eMTB assist mode when it arrived. After the update it was there and works great. With the Nyon, you will not have to go to the dealer to get the updates installed.
- Have the app loaded to your phone. Here is a link to an Android app download https://ebike-connect.en.aptoide.com/
Take a photo with your phone of how the cable runs from the controller to the display mount. - Mine was wound loosely around my handlebar (see my photo above).
- Loosen the screw at the bottom of the intuvia controller and take it off the left side of your handlebar.
- Slightly loosen all four screws on your intuvia display mount and rotate it on the handlebar so it is as upside down as possible.
- Carefully remove the four screws holding the small panel to the back of the mount.
- Carefully remove the controller interface panel taking care to catch the fine weather-sealing, red gasket
- Make sure the fine, red sealing gasket is in its groove before you place the Nyon controller interface on the back of the display mount.
- Secure the four screws.
- Turn on the Nyon. You will get the 580 error message. Ignore it push the up or down button.
- Make sure you are within good range of your home wifi network.
- Get into the settings menu and set up your wifi, enter password, etc.
- The Nyon will automatically want to update to the latest version. Let it do that.
- On your computer go to https://www.ebike-connect.com and set up your account/profile.
- Start exploring and playing around.
- Create custom ride and fitness screens.
- Open up your portal at ebike-connect.com when you get home from riding. All the legs of your route for the day are mapped out and recorded in detail while you are walking from your bike to your computer...too cool.
- Create your next route on your computer and download it to your nyon...ready to go when you turn on your bike.
- I was able to buy the custom ride modes and topographic range features from the goolgle play store here in the US once the app is installed.
Nyon is the best looking, most useful bike computer I have seen. The only negative is that it takes about 15 seconds to boot up before you can select assist levels and begin your ride.
